Can cold weather screw up transmission settings?
RE: Can cold weather screw up transmission settings?
On one of my previous threads someone chimned in about what the changes actually were. If you lower the shift pressures all the way to -25% it will help but still shift a little hard. The best way is to have mikel get you a custom tune so you can then set the shift the way that you want it.
2000 GMC Sierra 5.3 2wd ecsb
Denali cluster
Denali headlights
Corsa sport
Outlaw intake
U7198 custom tune (93)
03 Silverado taillights
debadged
shackels
20" wheels
Thats what I did, but only by -2%. It works until you jump on it and then (only occasionally) it will keep shifting hard after that.
99' Silverado 5.3L 4X4
- 4" Cold Air Intake
- Throttle Body Spacer
- 180 Powerstat
- Predator Programmed 93 (Modified)
- Clear Corners
- 17" GMC 6-Spoke Rims
- Alpine and MTX System
- 180 Powerstat
- Clear Corners
