Caliber SRT4, Avenger/Sebring/200, 14 Ram 6 speed added!
sohfast94
Re: Caliber SRT4, Avenger/Sebring/200, 14 Ram 6 speed added!
Post by sohfast94 »
awd1990tsi wrote:so do we have any specs for whats been modified in the tunes right out the box?
Also the advertisement for the Caliber srt4 on the DS homepage shows that it's supposed to have a 93 and a 91 tune as well as a factory hp tune. The only ones that are available on my unit after the updates are the 93 tune, and a modify stock tune. Just curious if that was a typo on the ad, or if something didn't go right when updating my trinity.
That will addressed today.
list of things adjusted in the tunes?
Boost
No timing really
torque management (A LOT)
ETC (for throttle pull etc...)
calculated torque values for maximums and NOV
WOT AFR
to name a few.
Insert Clever comment here...
91 tune added here.
trinity_dcx_gas-1t11cg_update.crom
(8.59 MiB) Downloaded 505 times
dusterman
Post by dusterman »
BRR wrote:My 2013 Avenger R/T is a rocket!
I flashed just like everyone else, but I will strongly recommend those who have backed up there cpm software and flashed with DS software, remember to shut down everything when the DS programmer tells you too! This means once the initial flash is in, you have to shut down the CAN bus, this is accomplished by turning the key off, unplug the Trinity, open the drivers door. Once this is completed, you can close your door, turn your key on and try to start the car. If the car starts, your good, now plug the programmer back in and perform the flash update again based on the tune you want to install. Once the install is completed again, follow the instructions on the Trinity and all will be well.
It seems the pcm gets confused for a moment and thats why you have to disconnect the Trinity as the Trinity keeps the CAN bus alive and you can't totally get the pcm updated. It is time consuming at the initial install, but once thats completed you can change the tune to any DS tune within a minute.
Currently I'm running the 93octane tune on my R/T, I also have a Mopar CAI and exhaust. The few adjustments I made were:
Cooling fans on about 20deg earlier than stock
WOT - added 5% fuel
Rev limiter in Neutral/Drive maxed out
Speed limiter maxed out
When I take off in Autostick w/traction control disabled by OEM button and not DS, the car blazes the tires in first, I go to grab second at 7000rpm but the OE programming takes over and shifts before that, then I grab 3rd and before I know it I'm already hitting over 60mph.
Mike,
Is there any way to bypass the OEM upshift/downshift feature on the Autostick cars?
My R/T pulled hard right up to the OEM shift point, and I feel the car can rev higher than that and keep pulling. Another thing is TQ converter lockup, I would like to see if that's possibly adjustable as I would not like to see it lock until I'm cruising at least 50mph or higher in 5th or 6th gear. Currently it still locks up in 4th at the stock level and I hear my car start bogging when it happens because depending on throttle input/speed it is really affecting my overall MPG because it locks up way to soon and I have to give more throttle to get it out of lockout to maintain the speed I'm in at 4th gear.
All in all, I'm definitely impressed again with the DS programmer!
Thanks again for finally getting a tune out for us FWD performance people!
I agree no matter what I do the car shifts first gear no more then 5800 rpm
curtis_bolton
Post by curtis_bolton »
hi i have a 2008 Dodge caliber srt4 i have the diablo sport trinity tuner and i have put the modify stock tune on my car since there is no 91 octane gas tune and my car was full of 91 octane i am just wondering i just bought a HKS blow off valve kit with the mpx up pipe kit i am wondering if i can still use the modify stock tune or do i need a custom tune and when i run the car out of 91 octane fuel and put in 93 octane will i need a custom tune there or can i just use the tune that is provided on my programmer or is there a way to get a 91 octane tune and id so what the difference between the 91 octance tune and the 93 octane tune
highpsi
08 caliber srt4 problem help please
Post by highpsi »
awd1990tsi wrote:updated my trinity, went to install it on the car, picked 2009, dodge, caliber srt-4, 2.4L turbocharged, as soon as I go to the performance section it tells me I need an update. I've done the 1r11 update and both the dcx updates that were released on 3/14 is there something I'm missing here?
Im having the same problem. :crashing:
Re: 08 caliber srt4 problem help please
its asking you to connect to a pc to get an update for the vehicle itself...
highpsi
Re: Caliber SRT4 not connecting
Post by highpsi »
I have done the update when i plug in to the car it says
Trinity dcx_gas does not support Calid 05155201AB update might be available
sohfast94
Post by sohfast94 »
Someone is sending the 201a PCM and once I have a read of it I'll add it.
dusterman
Post by dusterman »
My car wont do anything now!!! Tried to put stock tune back on and it froze on the turn key to off for like 5 minutes which In turn I had to unplug it and bow it says after it tries to re tune back to stock pcm: error write failed (-1). Need help stuck at worj with a car that doesnt do anything.
highpsi
staged pcm
Post by highpsi »
is there any update on the 201a cali? :?: customer is super ready to get tunned
Re: staged pcm
highpsi wrote:is there any update on the 201a cali? :?: customer is super ready to get tunned
getting closer.
RysaMess
Post by RysaMess »
How close is close??
Joeysrt4
staged pcm
Post by Joeysrt4 »
Any information on the tune for the staged pcm? Have the trinity in hand ready to go!
nolosrt4
Post by nolosrt4 »
Hi. Good night mi question is if I can tune with my diablo sport trinity a PCM that has the MS1k tune already, or if I could saved that existing tune into my diablo sport trinity.
ms1k will be wiped out if you use the trinity or intune on that PCM.
