Page 2 of 3
Re: Caliber SRT4 Intune
Posted: Tue Mar 18, 2014 5:11 pm
by sohfast94
Boost leaks or BOV. Check vacuum lines etc...
Posted: Wed Mar 19, 2014 3:04 am
by cornwellbs
ill double check everything again. i also cant adjust any parameters from my intune, the icon is there but its wont let me select it.
Posted: Wed Mar 19, 2014 9:14 am
cornwellbs wrote:ill double check everything again. i also cant adjust any parameters from my intune, the icon is there but its wont let me select it.
choose the option to modify the tune after you select the tune.....
Posted: Wed Mar 19, 2014 2:36 pm
by cornwellbs
The only options I have are "tune vehical" then either "write tune" or "restore factory tune"
Posted: Wed Mar 19, 2014 3:07 pm
right...tune vehicle, then write vehicle, then pick the tune, then choose the option to modify the tune when it asks you if you want to do so.
Posted: Wed Mar 19, 2014 4:57 pm
by csrt_carlosg
mikel wrote:right...tune vehicle, then write vehicle, then pick the tune, then choose the option to modify the tune when it asks you if you want to do so.
Hey I have a question the advertisement says that the tunes preloaded are 93 octane(Diablo tune), 91 Octane tune and factory HP tune but when I tuned my vehicle the only option I got was Diablo tune and Factory HP tune, what about the 91 octane tune?
Posted: Wed Mar 19, 2014 5:02 pm
I thought Brian addressed this earlier, its fixed in the next update.
Posted: Wed Mar 19, 2014 5:13 pm
by csrt_carlosg
mikel wrote:I thought Brian addressed this earlier, its fixed in the next update.
Ok I must have not seen if he addressed it but I will plug to PC for latest update.
Thanks.
Posted: Mon Sep 08, 2014 6:39 pm
by dailymurdersrt4
I'm having the jerking issue with mine as well, anywhere near 0 on the stock boost gauge (between vac and boost) it's really choppy and jerks me back and forth. Stock WG, stock turbo, one range colder NGK plugs gapped at .034. Any insight on what i can do to fix this? of course the intune is up to date and set on the diablo tune (93 oct) with no parameters adjusted
Posted: Thu Oct 09, 2014 8:04 pm
by Holobaugh
My intune is doing the samething with the jerking. Anyone solve this problem yet??
Posted: Thu Oct 09, 2014 8:07 pm
by Holobaugh
Also can't adjust any parameters
Posted: Tue Oct 28, 2014 12:38 pm
by Wamit
Mine too. I installed the 91 tune and a set of NGK Iridiums gapped @ .028. Rough idle but ran great for a couple of hundred miles. Then it developed a hesitation at low rpm (take off stumble). I regapped the plugs to .032ish and it now idles silky smooth, accelerates smooth, a huge improvement, except now I have the jerking, boost/vac gauge bouncing when close to 0. It don't seem to start happening until rpm's are around 3000 and up. Only thing I changed was the gap. To be honest, it made the engine so much smoother that I would hate to have to go back down on the gap.
Posted: Tue Oct 28, 2014 1:01 pm
can you guys post a log of this issue happening?
Posted: Tue Oct 28, 2014 1:36 pm
by sohfast94
Everyone return to stock and load this. It has all the tune updates as well as boost control.
But you MUST go back to stock before loading it.
Once loaded you can tune as normal.
Posted: Thu Oct 30, 2014 11:36 am
by Wamit
You nailed it!! This update fixed my issues. Just for the sake of knowledge, what parameters were corrected/adjusted? Thanks.
Also, on a side note, before I manually installed this update on my intune, I let it automatic update to see if this (1t01ef.ITF) would update on its own. It did not. It updated to the same tune that was already installed (1r03??).
