Issues with Throttle Boost, 2014 Sierra
Zach
Re: Issues with Throttle Boost, 2014 Sierra
Post by Zach »
Hey guys, I've been working on the shift settings and dialing them in for the throttle boost. I'd like to offer a custom tune to those of you that are experiencing issues with your shifting. If you would please post your "last tune written" and "backup" files from your tuner, I will make the adjustments and have the back to you to load into the truck. Please post both the ECM and TCM last tune written's and backups.
Maverick1
Post by Maverick1 »
mikel wrote:Yes...we have been spending more time with our 14 sierra and have gotten things ironed out a bit when using the throttle boost.
New updates should be ready in the next week or two :)
Excellent 2nd to 3rd a real dogggggggggggg! Shifts there sometimes at 1200 RPM the massive throttle input needed... Please post when fix is up..
Thanks,
2019 Ram Laramie Longhorn 1500 5.7 392 rear ends, new style.
8-Speed
All available options
Unlocked pcm and I3 Diablo Tune
Magnaflow catback system
K&N cold air intake.
Thanks,
as mentioned, if you post the files he will make you a custom tune asap :)
Maverick1
Post by Maverick1 »
I change to the stock tune. can you use it to modify for a Daiblo Custom Tune? If you can add as much throttle boost as possible. Here it comes.
8-Speed
Zach
Post by Zach »
Maverick1,
Load these up and give it a shot. You should notice a big difference in drivability and in the transmission shift points. Please give me some feedback on this. Enjoy!
ecm_12659743_maverick1engine.grg
(103.15 KiB) Downloaded 588 times
tcm_24271132_maverick1trans.grg
(46.22 KiB) Downloaded 355 times
Maverick1
Post by Maverick1 »
Zach wrote:Maverick1,
Shall do this evening and report back. Great service.
8-Speed
Maverick1
Post by Maverick1 »
Vast improvement. If I may, under very light throttle input shift from 1-2 and 2-3 a little high, close to 3000. Under a swift take off with more input it is still at 3000 but fine. If just seems a little high with the minimal input. Thanks, not the same truck......
Most younger people will like it but with my Magnaflow exhaust, you know what I mean...
8-Speed
Zach
Post by Zach »
Thanks for the input. I adjusted the shifts a little bit in regards to the symptoms you were stating. Try this out.
tcm_24271132_maverick1trans_rev1.grg
(46.22 KiB) Downloaded 439 times
Maverick1
Post by Maverick1 »
Zach wrote:Thanks for the input. I adjusted the shifts a little bit in regards to the symptoms you were stating. Try this out.
Got it a will load and try tonight. Thanks so much again. Hope you understood my eval.
Regards,
Larry.
8-Speed
ziknazoo
Post by ziknazoo »
Here are my files. Like Maverick, I'd like the shift points to be moderate (stock like) and not 3000 RPM at light throttle.
John
TCM_24271132_LastTuneWritten.grg
(52.96 KiB) Downloaded 611 times
TCM_24271132_Backup.grg
(52.83 KiB) Downloaded 303 times
ECM_12659743_LastTuneWritten.grg
(111.76 KiB) Downloaded 302 times
ECM_12659743_Backup.grg
(110.88 KiB) Downloaded 348 times
ziknazoo
Post by ziknazoo »
Zach wrote:Hey guys, I've been working on the shift settings and dialing them in for the throttle boost. I'd like to offer a custom tune to those of you that are experiencing issues with your shifting. If you would please post your "last tune written" and "backup" files from your tuner, I will make the adjustments and have the back to you to load into the truck. Please post both the ECM and TCM last tune written's and backups.
Is this separate from rolling out an update? Will the update happen or will we just have to use the custom tune?
I posted my grg files in a previous post.
Thanks,
john
Thanks,
john
there will be an update once we are sure this is what everyone is after :)
Zach
Post by Zach »
ziknazoo wrote:Here are my files. Like Maverick, I'd like the shift points to be moderate (stock like) and not 3000 RPM at light throttle.
John
Can I get your info.xml file from the intune drive please?
ziknazoo
Post by ziknazoo »
Here you go... (Filed deleted because it had my VIN)
John
there is something odd about the files you posted, can I ask you to maybe restore the stock tunes, update the device on a PC, then reload the tunes and then repost the files?
Thanks!
