2014 Dodge Challenger SXT and Traction Control
Re: 2014 Dodge Challenger SXT and Traction Control
Yes, those are the correct lights on the dash for this change, and ESP is dead with that tune loaded.
Excellent. I appreciate it.
I will be watching for a solution to the Traction Control disable issue in the Quick Adjust menu.
Sorry, but I have one more question. Before the tune was installed, I could hit my traction control button on my dash 1 time (my Charger does not have STP ... hence the reason why I have to fully disable t/c and esp through the tuner) and it would illuminate the light on the dash of the car leaving black marks with the word "OFF" below it.
After the tune (which already causes the ABS and the car leaving black marks to be illuminated) when I hit my traction control button on my dash, it does nothing. The car leaving black marks with the word "OFF" below it no longer lights up.
I just wanted to confirm that this is what it should be doing. In the back of my mind I guess I pictured the button on the dash still doing what it always did ... especially since it caused a different light to illuminate than the 2 lights that are affected by the custom tune.
Just let me know. Thanks!
P.S. After the custom tune was installed I was able to smoke the rear tires for the first time since owning the car.
yes, the button is useless with that tune.
Thanks for the confirmation, as well as the swift responses. Much appreciated!
billfromislip
mikel,
I've also had the same problem for 4 months now waiting for the traction control disable feature to work properly in the quick settings menu of the I-1000 DCX. Would I also be able to get the same type of tune with the system disabled? I have a 2014 R/T.
Please let me know - it would be greatly appreciated.
Thanks,
Bill
Thanks,
Bill
Same here. That feature has never worked for me. Since I do not run it at the track, I never much cared. I have no wish to disable my ABS on the road, at least not on an everyday basis.
2011 300C-Tungsten, Johan tune, reso delete, Lockpick C8, modified airbox
yes, anyone whop wants this, post up the LTW please.
billfromislip
Here's my last tune written file. Is this all you need to make the traction control disable tune? It will be nice to finally be able to disable it when I want to.
Thanks,
Bill
Thanks,
Bill
Here is mine Mike. Thanks for all the assistance!
here you gobillfromislip wrote:Here's my last tune written file. Is this all you need to make the traction control disable tune? It will be nice to finally be able to disable it when I want to.
Thanks,
Bill
this tune is locked, you will need to ask your tuner to take care of this.Smokey613 wrote:Here is mine Mike. Thanks for all the assistance!
Will do. Thanks Mike!
billfromislip
Thanks mikel. I appreciate the quick response. I can't wait to give it a try over the weekend.
just checking is there a time frame for when a update to fix this problem will be available the custom tune works fine but takes to long to upload everytime the wife drives the car i have to switch it back...
[url=https://www.cialispascherfr24.com/]this[/url]
