Page 2 of 2
Re: custom tune not loading
Posted: Wed Jan 14, 2015 11:36 am
by 6.0swhatuneed
Thanks a lot, I'll see what it does tonight. Hopefully this just a totally random problem.
Posted: Wed Jan 14, 2015 10:22 pm
by 6.0swhatuneed
Well, I believe the gear ratio is right, I don't have any lights on now. My fans still won't kick on. If I manually ground the harness they work. Any ideas? I do appreciate your help Zach.
Posted: Thu Jan 15, 2015 9:46 am
by Zach
Unfortunately, looks like an issue on your end. If i recall correctly, the fans were working perfectly, and then one day they stopped. That tune has all of the changes for the fan set properly and they are the same settings that you were using originally when the fans were working properly.
Posted: Fri Jan 23, 2015 9:37 am
by 6.0swhatuneed
Hello again. I finally figured out my problem and my pcm was bad. I purchased a new one and installed it, truck runs with no codes. I can't get the custom tune to come up on the intune now. Will the old tune work with the new pcm? It is programmed for my truck and vin. Again, I really appreciate all the help.
Posted: Fri Jan 23, 2015 9:40 am
you'll need to redo the custom tune from the new backup file.
Posted: Fri Jan 23, 2015 9:45 am
by 6.0swhatuneed
Okay, here's my tunes again, hopefully for the last time.
Posted: Wed Jan 28, 2015 11:00 pm
by 6.0swhatuneed
Anyone had a look yet?
Posted: Thu Jan 29, 2015 9:38 am
by Zach
Tune attached
