Page 2 of 4
Re: Sonic/Cruze 1.4T now supported!
Posted: Tue May 12, 2015 10:22 pm
by XxScottxXN
Tried it again....same results! I also tried calling the tech support line at 3:35 my time...and was on hold for 30 minutes and no answer. The trinity still won't load the backup. I will try calling again Friday with better luck...I HOPE!!
Posted: Wed May 13, 2015 12:18 pm
theres gotta be a piece missing here...key all the way on?
latest trinity crom updated?
Posted: Wed May 13, 2015 12:28 pm
by XxScottxXN
Is this the cron... v.1r13j? Key is on. But it tells me that there is a performance tune already installed...not possible!! And everything works perfect on my Camaro!! I'm pretty positive about the install method since I've done it several times over the last 4 years.
Posted: Thu May 14, 2015 9:43 am
by XxScottxXN
Would the factory have tuned this for the turbo?
Posted: Thu May 14, 2015 9:54 am
by 06MonteSS
it would still be a factory GM stock tune.. not an aftermarket tune....
Posted: Thu May 14, 2015 1:48 pm
by XxScottxXN
Do I have the correct update installed in the tool??
Posted: Fri May 15, 2015 8:38 am
by XxScottxXN
What extention should I call
Posted: Fri May 15, 2015 8:51 am
I dont see this getting fixed over the phone, I really dont know what might be happening here.
My only thought is it maybe the tool, how long have you owned it?
Posted: Fri May 15, 2015 8:54 am
by 06MonteSS
he's had his trinity since around 2011/2012....
Posted: Fri May 15, 2015 9:20 am
by XxScottxXN
I've never had any problems with the tool. And I've used it many times. I bought it from Lew! What do I do now...seems like it won't support the Cruze.
Posted: Fri May 15, 2015 10:31 am
by XxScottxXN
Tried it again...same results! Emergency brake on, stereo power off, no accessories plugged in!!! Plus...flashed my Camaro and no issues. No possible way it can be the tool!! All of my updates over the years have been downloaded with no problems. The issue has to be on your side...not mine. I have had this car since it had 6 miles on it and no way it can have a performance tune in it already!
Posted: Fri May 15, 2015 10:34 am
and you are for sure restoring the tune to the camaro before you try it inthe cruze?
Posted: Fri May 15, 2015 10:45 am
by XxScottxXN
Absolutely positive!!! It tells me that the tool is unmarried!!
Posted: Fri May 15, 2015 11:01 am
ok, let us look into this a bit more please.
Posted: Fri May 15, 2015 11:03 am
by XxScottxXN
OK!!
