2015 F150
Re: 2015 F150
Somethings off here. You said it didn't give you a 2015 F150 3.5L selection in the vehicle dropdown?
Insert Clever comment here...
Re: 2015 F150
it sounds like he was able to select 15, but the description after that was saying 05-14, might need to update that description.
Re: 2015 F150
It says choose 2004-2014 ford gas vehicles (ford_can_gas)
Then yes or no
Then yes or no
Re: 2015 F150
But it gives me right from the begining the option to select, 2015 then ford, then f150, then 3.5 ecoboost. Then it gives Mr the "this application supports" screen and lists everything when I hit continue it gives me the 2004-2014 message.
Re: 2015 F150
Oh you just need to scroll down and you'll see the rest. That's a different message.
Re: 2015 F150
When I read through the message I see the 2015 in there, that's the only reason why I hit continue yesterday when I saw that pop up, do you think it was because of the speed limiter option I chose? Or should that not have effected the tune that way?
Re: 2015 F150
for now try loading it with no limiter changes and see how it behaves if possible.
Re: 2015 F150
Loaded the 87 tune again, and its like my throttle isn't even connected, if i put it in gear I can idol around but throttle as no affect, and in park it has no affect.
Re: 2015 F150
Did this happen immediately? Did you get the last tune written from the tool with the 87 octane tune installed?Roiceed wrote:Loaded the 87 tune again, and its like my throttle isn't even connected, if i put it in gear I can idol around but throttle as no affect, and in park it has no affect.
Re: 2015 F150
The first tune I loaded was 91 performance, that one worked, then I drove it back home, filled the tank with e87 and loaded the 87 tune, it has not actually worked with the 87 tune on it. How can I send yout the tune information?
Re: 2015 F150
New update. Load this to tool and retry for me.Roiceed wrote:The first tune I loaded was 91 performance, that one worked, then I drove it back home, filled the tank with e87 and loaded the 87 tune, it has not actually worked with the 87 tune on it. How can I send yout the tune information?
- trinity_ford_can_gas-1t13fa_update.crom
- (3.57 MiB) Downloaded 284 times
Re: 2015 F150
I tried it, same thing for 87. I reinstalled the original backup and works fine again. How can I send you the last tune from the device?
Re: 2015 F150
You have to program the vehicle and then read out the last tune written with dsdownloader by hitting get tune from tool and when the window pops up select last tune written.
Also, take a pic of the options show information screen and email it to me at brianm<at>diablosport.com
Re: 2015 F150
Loading the tune on my truck now, at this point I think it's something dumb that im over looking, I have noticed that it does say 87 is installed and in the info it says something like bus connection not verified. Would that be why the 0 to 60 doesn't work?
Re: 2015 F150
I'm still having the same issues as before. I haven't seen any other post about anyone else having the same issues. Is there anyway I can completely reset my tuner. Drivers and all and start from scratch and give it a shot again?
