2015 F150 EcoBoost tunes now available from Diablosport
kellyfj10
Re: 2015 F150 EcoBoost tunes now available from Diablosport
Post by kellyfj10 »
kellyfj10 wrote:The version is v.1r13f. I loaded the premium tune and had the same result, no throttle response after a couple of minutes. Then when I tried to load the original tune back it said that the tuner was used to load a 2004-2014 f150 and it wouldn't let me go any further. After several attempts it let me load the factory tune back.
Mike, I think I have the latest tune. What do you advise?
juangorena
Post by juangorena »
this is what I experienced it happened to another buddy he posted this :
Actually, I just went back out to my truck to move it into the driveway, had the 87 tune on it. Pulled it in, then lost all throttle in it. Wouldn't move forward at all, put it in part and it wouldn't rev at all. So I returned it to the original settings and it worked fine again, actually it even seemed more peppy then the tunes on it. Maybe I did something wrong? Or are these still the test tunes for the truck? Either way I figured I'd give you some feed back on it.
juangorena
did you experienced the same power loss ? . did it get fixed ? I uploaded the file trinity_ford_can_gas-1r13f_update.crom with speed limit off performance 93
kellyfj10
Post by kellyfj10 »
I didn't know that there was an updated one. But yes I had no throttle response. I will try to download the update and see what happens.
kellyfj10
Post by kellyfj10 »
mikel wrote:try a different tune if you get a chance please.
I tried the premium tune and had the same result. No throttle response after 3 or 4 minutes of driving.
juangorena
Mikel , we have been experiencing completely throttle loss, it was very dangerous to me since it happened in the middle of the traffic , do you have an update or at least are you working to solve this issue?
Regards
Omar
mikel wrote:We have released tunes for the 2015 2.7 and 3.5 Ecoboost models on our T-1000 Trinity and I-1000 inTune models.
Tunes for 87, 91 and 93 octane are available for both applications.
PRELOADED TUNES:
93 PERFORMANCE TUNE:
2.7L +40 HP | + 70 TQ
3.5L +70 HP | +100 TQ
91 PERFORMANCE TUNE:
3.5L +65 HP | +90 TQ
87 PERFORMANCE TUNE:
2.7L +30 HP | + 60 TQ
3.5L +50 HP | +70 TQ
TOWING TUNE:
MILEAGE TUNE:
TOWING TUNE:
Available end user parameters:
Disable Auto Start/Stop (2.7L Only)
Global Timing Adjustment
Gear/Tire Size
Idle RPM
WOT Fuel Rich/Lean Adjustment
Cooling Fan Control
Intake/Exhaust Cam Adjustment vs. RPM
WOT Spark Timing Advance/retard
Raise Speed/Rev Limiters
Shift Points/Shift Firmness
Tunes are released and available now on any T-1000 Trinity or I-1000 inTune.
Let me know if you have any questions!
We are investigating.
Please load this update then reload the tunes, it should be corrected.
trinity_ford_can_gas-1t13ga_update.crom
(3.58 MiB) Downloaded 1159 times
Roiceed
Post by Roiceed »
Uploaded that file, no change. 87 no throttle response. Tuning back to original now..
kellyfj10
Post by kellyfj10 »
mikel wrote:Please load this update then reload the tunes, it should be corrected.
I went for a short drive and seemed to be ok so far. I will update after a longer drive. Thank you for the quick work!
heath t
Post by heath t »
kellyfj10 wrote:
heath t wrote:Mine has a bad hesitation at part throttle. Its spitting and sputtering. Between 1/4-1/2 throttle, the truck lurches and sputters. No backfiring, just acts like it loses all throtle or fuel fo ra spilit second. It does it constantly and consistantly at part throttle. Im also currently running the premium tune. Ill try another tune n the morning.
Did you try a different tune?
Yep. Same result.
kellyfj10
Post by kellyfj10 »
I put the updated tune in, drove it lastnight and it was fine. Got in it this morning and driver it for 5 minutes it was fine, went to get on the highway and lost all throttle. I was using the premium tune. Also, when I installed the premium tune, I didn't notice a difference in the performace. If anything, I thought it was a little more sluggish then the normal tune.
OK, we're gonna sort this out.
juangorena
any news ? did you sort out this issue ? i even tried using original file i just modified the speed limiter and i feel like misfire in cilinders also check engine light flashed :(
kellyfj10
Post by kellyfj10 »
mikel wrote:OK, we're gonna sort this out.
Mike, how we looking? Any updates?
Return to “Trinity Ford Gas”
