2.7 ecoboost calibration error
Re: 2.7 ecoboost calibration error
Here is the ITF
- FORD_TUNES-1t01zc.ITF
- (15.57 MiB) Downloaded 257 times
Insert Clever comment here...
it is telling me I need to register before I can update
Just drop that on the intune drive and it'll suck it up and load it.
load this to the intune drive and it will register then you can update.
- registration.itf
- (859 Bytes) Downloaded 187 times
got the files on, updated until all I get is error messages again. going to try it
you havent loaded the file he posted, please load the ford tunes 1t01zc.itf file to the intune drive and let the tool import it.ozzcrash wrote:Same issue.
then when it reboots, go to settings/advanced/clear all updates, then plug it into the truck and it will ask for update, then it will work on the PC.
I've installed the file to the intune, tried it in truck, (PCM may need update error) came back in and updated (autoupdate isn't working (Calibration error) so I manually check for updates and it installs a update). Tried in truck again, same PCM error. I deleted the previous info as you suggested. Ive watched it prepare, write, verify and reboot. Ive tried every combination I can think of.
Right now the only file/update installed is the file you posted. On the intune under firmware info is Ford Tune Db: 1t01zc Ford PID Db 1r01b. Ill post the info again...
- info.xml
- (1.8 KiB) Downloaded 182 times
its not looking for an update here, please go to the truck and if it asks to check fro an update click the green check then post a new info file.ozzcrash wrote:I've installed the file to the intune, tried it in truck, (PCM may need update error) came back in and updated (autoupdate isn't working (Calibration error) so I manually check for updates and it installs a update). Tried in truck again, same PCM error. I deleted the previous info as you suggested. Ive watched it prepare, write, verify and reboot. Ive tried every combination I can think of.
Plugged it into truck, it said PCM thing and I clicked checkmark. Here's the info again.
- info.xml
- (1.89 KiB) Downloaded 194 times
Proceeded to update on PC, manually checked and it installed update, heres info
- info.xml
- (1.89 KiB) Downloaded 201 times
Went back to truck, asked for PCM calibration again. Heres the info
- info.xml
- (1.9 KiB) Downloaded 191 times
Updater wont let me automatically or manually update anymore. Hope we can figure this out.
were on it.
Just checking in.
