u7194 2007 NBS GMC Sierra
devilish1500
devilish1500
devilish1500
good luck with that...
stepsidez71
problems
Is it possible there is something wrong with your truck? I saw on ctw forums that you have an edge now and are having the same problems. A lot of other people are running programmers to fix tire sizes and are not having problems. Could the shop have pinched or cut a wire for one of you ABS sensor when they put your lift on?
devilish1500
RE: problems
had the truck looked at and they say its fine. if the diablo shows wheel speed adn vehicel speed sensors on the real time data logging i may put it back on and get the difference in the two and get it fixed that way....I HOPE
RE: problems
I think there's a bad sensor somewhere. I'd remove the programming all together, and put stock tires on it and run it for a while to see if the lights go out. One of your wheel sensors has to be bad.
You've had issues both with Diablo AND Edge which leads me to believe the problem lies in the truck. I'd also consider taking it to another dealer for service.
Good luck
Good luck
2007 GMC Sierra SLT Vmax. 4.10 gears, Bedrug, Boss MT100 20x8.5 wheels/Kumho STX tires, Extang Bed cover, Light of fire, Denali Grill, GM Performance Intake and DiabloSport
CANUCKPREDATOR
RE: problems
The Predator does read diagnostic codes. Take a look and see if there is a code being thrown out there. Might be able to find a problem yourself instead of trusting the stealership.
devilish1500
CANUCKPREDATOR
devilish1500
