Page 2 of 2
devilish'
Posted: Tue Jun 19, 2007 11:37 pm
by budlite8
did you get the 7194 to program in a nbs 07 gmc with a 5.3l flex fuel.. mine would not,,? did i do something wrong???? your responce is greatly appreciated!!
Posted: Wed Jun 20, 2007 1:02 am
by devilish1500
yeah i did, i can atleast change the speedo. as far as engine power....maybe there's a difference
Posted: Sat Jun 30, 2007 3:07 pm
by devilish1500
my dealer wont give me a refund, what do i have to do to get one directly from you guy?
Posted: Fri Dec 07, 2007 11:54 pm
by devilish1500
thanks for no help....diablo is GONE and edge programmer is now in my truck!!
Posted: Sat Dec 08, 2007 1:12 am
good luck with that...
problems
Posted: Sat Dec 08, 2007 12:36 pm
by stepsidez71
Is it possible there is something wrong with your truck? I saw on ctw forums that you have an edge now and are having the same problems. A lot of other people are running programmers to fix tire sizes and are not having problems. Could the shop have pinched or cut a wire for one of you ABS sensor when they put your lift on?
RE: problems
Posted: Wed Feb 06, 2008 6:19 pm
by devilish1500
had the truck looked at and they say its fine. if the diablo shows wheel speed adn vehicel speed sensors on the real time data logging i may put it back on and get the difference in the two and get it fixed that way....I HOPE
RE: problems
Posted: Wed Feb 06, 2008 8:01 pm
by Stevens07
I think there's a bad sensor somewhere. I'd remove the programming all together, and put stock tires on it and run it for a while to see if the lights go out. One of your wheel sensors has to be bad.
You've had issues both with Diablo AND Edge which leads me to believe the problem lies in the truck. I'd also consider taking it to another dealer for service.
Good luck
RE: problems
Posted: Thu Feb 07, 2008 1:13 am
by CANUCKPREDATOR
The Predator does read diagnostic codes. Take a look and see if there is a code being thrown out there. Might be able to find a problem yourself instead of trusting the stealership.
Posted: Fri Feb 29, 2008 1:39 pm
by devilish1500
the lights stay off around town and short interstate drives. When i get up to around 65mph is when they come on now. They were coming on around 40 or even lower. i just keep trying more and more numbers.
Posted: Fri Feb 29, 2008 3:54 pm
by CANUCKPREDATOR
My truck does the exact same thing. The crom update (8r10) did fix it for about 10 miles longer. Hope this issue gets fixed up. I've read that most ABS computers will only accept about a 3% change before they have issues.
Posted: Fri Mar 28, 2008 10:15 am
by devilish1500
got it fixed, had a buddy use a tech 2 to read the speed difference in the PCM and ABS
