2014 5.3 chevy
Re: 2014 5.3 chevy
I can try skipping the tcm tune I haven't tried that. I always just did modified stock but never fooled with the preloaded settings. I'll try that and let you know.
Re: 2014 5.3 chevy
Got the 87 oCtane canned tune loaded no changes. Skipped tcm tune all together as requested. Still getting the banging shift at 100% WOT. I'm really at a loss now. Although I understand the PCM and tcm work together to find the proper shift points/pressure I'm not understanding what's going on here. Does it without any throttle boost added on my end.
Would really like to get this thing working properly so I can have the extra power as I'm putting a small lift and larger tires within the next 2 weeks.
Re: 2014 5.3 chevy
Would my issue possibly have anything to do with my drop in k&n intake filter? Just a factory replacement not a intake kit.
Re: 2014 5.3 chevy
OK, did you restore then reload and skip the tcm?
if not whatever you last loaded to the tcm is still there....
Re: 2014 5.3 chevy
does it do it stock??? maybe you got a bad tranny? a LOT of people have that issue with those trannies.. http://www.gminsidenews.com/forums/f53/ ... ms-164881/
Re: 2014 5.3 chevy
No issues whatsoever stock. Shifts nice and smooth under light and heavy throttle even pulling heavy loads even 100% WOT, no issues whatsoever. And yes I restored original tune then installed just the PCM tune and skipped tcm tune install.
Re: 2014 5.3 chevy
OK, we're on to something.
Post the current files from the tunes folder and the current info file please.
Re: 2014 5.3 chevy
They are posted previously in this thread. Nothing has changed. The truck is back on factory tune for now. I believe the file I uploaded previously had +15% throttle boost.
Re: 2014 5.3 chevy
OK, Im not trying to give you a hard time, but would you please post the current files from the tunes folder, and the info file?
If you restored and reloaded Id like to see whats there now.
Re: 2014 5.3 chevy
Ah ok. Just thought you may have been able to use the old files. I will upload them tonight for you.
Re: 2014 5.3 chevy
as requested. here are all the files on the device. 87 octane canned pcm tune unaltered and no tcm tune was installed.
- TCM_24271132_Backup.grg
- (53.27 KiB) Downloaded 221 times
- info.xml
- (2.42 KiB) Downloaded 230 times
- ECM_12659743_LastTuneWritten.grg
- (111.97 KiB) Downloaded 241 times
- ECM_12659743_Backup.grg
- (111.31 KiB) Downloaded 253 times
Re: 2014 5.3 chevy
Jeez y'all have a spambot issue on this forum. Thanks for deleting all the unneeded garbage in this thread. Any update on my issue?
Re: 2014 5.3 chevy
try loading this tcm tune with the same pcm tune and let me know if its good.
- TCM_24271132_test.grg
- (46.25 KiB) Downloaded 236 times
Re: 2014 5.3 chevy
first to 2nd seems fine all other gears still bang pretty hard at WOT.
- TCM_24271132_LastTuneWritten.grg
- (53.32 KiB) Downloaded 206 times
- (53.26 KiB) Downloaded 208 times
- info.xml
- (2.42 KiB) Downloaded 211 times
- (111.96 KiB) Downloaded 176 times
- (111.31 KiB) Downloaded 222 times
Re: 2014 5.3 chevy
Hmm...I will need to look at the files, ALL I changed inthe tcm tune was to let it shift a little harder for 1-2, didnt touch anything else...
