2006 ford f-150 eng. mis
rhogeland
RE: Re: RE: Re: 2006 ford f-150 eng. mis
Ford fixed the problem with the truck. After changing everthing out on the truck . It had a bad computer or that is what they told me. What ever they did fixed the problem.
rhogeland
Re: RE: Thank you. I will call the dealer and set up an apoi
Did you ever cut open you oil filter to see if there is any metal in side . If not there should not be anything wrong with the bottom end of your motor . That would be one of the first signs of something wrong.Also try running a colder plug and see if this helps.
