2016 Chevy 5.3
Re: 2016 Chevy 5.3
This is the truck silverado Z71 4X4 2016, i wan't disable the speed limiter, and firm transmission time with 91 octane gasoline and 285/45/22 tires
Re: 2016 Chevy 5.3
this is the info file saved in the i2 after tryng to install it
Re: 2016 Chevy 5.3
i installed the file you send me and only appears the option in advnaced tunning, and the parameters i can modify was the transmission only, i can't modify speed limiter, tires
MakeItAMudLight
Re: 2016 Chevy 5.3
I'm actually having the same issue as above with my 2016 GMC Sierra with the 8 speed. I have also tried the solution you provided without any luck. I've attached the backup from my truck.
