Why can't I see turn off MDS for my i2010
Bobbyjo
Re: Why can't I see turn off MDS for my i2010
Post by Bobbyjo »
did anybody find out how get the fix for for the i2 tuner to adjust the rev limiter and mds shut off etc.
Bobbyjo
Post by Bobbyjo »
I found where to get the parameters to adjust. I put it back to stock tune then when back in and selected advanced tune and then select standard tune this will give the Diablo tune and the 91&87 tunes and the modify parameters will be there do the adjustments.hope this helps
you got it.
carolinayarber
Post by carolinayarber »
So if I have the 93 octane. Do I have to to restore to factory then do a 91 octane to be able to access all the parameters? Or is there a way to keep 93 octane and still access to all the parameters?
select the 93 tune then choose the option to modify the tune.
grizzjeeper
Post by grizzjeeper »
Same here. 2015 ram 6.4 91 tune. Only option is Tire size and Traction control. No MDS no throttle boost and no transmission setting. Tire size and traction error out and say wont write. What gives?
are you sure you are looking in the modify parameters menu, as opposed to the quick adjust menu, which should only have the items you list there?
Dex_UK
Post by Dex_UK »
mikel wrote:are you sure you are looking in the modify parameters menu, as opposed to the quick adjust menu, which should only have the items you list there?
This sounds like something which would be helped by a step-by-step with screenshots showing the sequence of menu options to select?
are you guys 100% sure you are selecting the modify parameter menu, NOT the quick adjust menu?
benpgreen
Post by benpgreen »
I still have the same issue, I'm in the correct menu and all I see is what is in the screen shot I posted. I can get those options one time if I return the vehicle to stock but then I have to return the vehicle to stock each time I want to change options in that menu. I honestly just have up in it because I kept being told the options are there when they clearly are not there in the screen shot. I have called and posted on here with no resolution, it looks like more people have the same issue.
benpgreen
Post by benpgreen »
I started this thread over 4 months ago and it still no resolution. Is there any possibility of this issue being resolved? I am positive I am in the correct menu, obviously more users are having this issue what can be done to fix it? Do you give refunds for your product not working as advertised?
Yes, it is being investigated and progress is being made, a fix is coming.
BlueKryptonite
Post by BlueKryptonite »
I am also experiencing the exact same thing. 2014 Ram 1500 5.7 8 speed
2014 RAM 1500 5.7, 8 speed, 3:92
BlueKryptonite wrote:I am also experiencing the exact same thing. 2014 Ram 1500 5.7 8 speed
if you cant disable it, post the tunes from the tunes folder on the i2 drive and I will make a custom tune with it disabled.
benpgreen
Post by benpgreen »
That would still not give me all of the options normally available under that menu, specifically cooling fan control. Is a fix still in the works?
