Disgusted-ranting
Is all this drama worth the added power ?
I recently started using my Predator programmer and it has tons of power. My truck is like a big rocket, but when it's on my truck it idles different, and when I'm coasting it surges too. It doesn't happen alot,but from reading all these other complaints,it has me concerned if I should even be using the programmer anymore. What's a CALID # ? It seems like this programmer has more negative feed back, than positve. Which scares me.
Does anybody out there use there programmer problem free ?
Dodgezilla
RE: Is all this drama worth the added power ?
Mine works great. It just doesn't have many of the advertised features. I don't care about most of them but I really wish it would read codes.
04 Ram 2500 RARE Timberline Green 4x4 305/555 CTD/Stock48RE,DS Predator,VA C3.2,HE351 turbo, 2nd gen intake, BHAF,Custom 4" exhaust, More stuff....
Ok, i got a truck in here guys.
One question, the rough idle is the same in all the tunes or is one worse than the other?
Please let me know asap.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
I had the tow tune and it was worse and more often. I have the Perfoamance tune now and it still happens. but not near as bad or as often. I haven't tried the extream for any amount of time; my clutch won't hold it.
06 CTD, AFE, 6 speed 3.73, predator
Ok and you had, 35325551AQ for calid.
Checking it out...
Checking it out...
Diablosport INC
Diablosport INC
Idels bad on all tunes !
Mine Idles bad in tow,Economy,and Extreme tunes. There all the same.I mostly drive it in Tow,and Economy because my trainy isn't beefed up enough for the extreme rkl tune. Is this bad for the engine to do this ? When your driving it runs good, Except for a occasional surge,but when ideling it sounds like crap. I'm not concerned about reading codes, I just don't want my engine to get damaged. My truck is a 2006 with the 5.9. I have AFE air box,MBRP Cat back dualls,and CFM intake. When I turn the tuner off my truck idles back to normal.
Re: Idels bad on all tunes !
i am gunna have to say that it has entirely too much timing, and that is not good in the cold mornins and until the engine warms to 175 degrees.Diesels NEED three things fuel,HEAT,oxygen.when an engine iz cold and u are dumping raw fuel into combustion chambers,it ain't good on nothing and is the wrong way to warm up yur engine.I think i would take the truck back to stock until it iz fixed.Or some people with be replacin injector nozzle. my .02akdiesel wrote:Mine Idles bad in tow,Economy,and Extreme tunes. There all the same.I mostly drive it in Tow,and Economy because my trainy isn't beefed up enough for the extreme rkl tune. Is this bad for the engine to do this ? When your driving it runs good, Except for a occasional surge,but when ideling it sounds like crap. I'm not concerned about reading codes, I just don't want my engine to get damaged. My truck is a 2006 with the 5.9. I have AFE air box,MBRP Cat back dualls,and CFM intake. When I turn the tuner off my truck idles back to normal.
'03 6-speed, afe stage 2, ats arc flow, 4" str8 threw exhaust,Smarty/Puck, TST PMCR R37, Fass 150, SPS 62/14,60# boost,1600*pyro gauges
mmm...diesel
RE: Re: Idels bad on all tunes !
Mine is all the same on all the settings identical to issues akdiesel has.
2006 Patriot Blue 4x4 6spd QC SWB Edge Juice W/Attitude, boost foolin, k&n replacement filter, 36" Magnaflow (trade for Donaldson), Predator stacked w/edge, puck in box
dunejunkie
i dont have the surge problem since i installed r16 version but i do have a slight rough idle i mstly run the rkl ecept when towing on occation let me know if u need calid.
06 mega cab predator/puck stack,afe stage 2,cfm+ plentum,zilla boost fooler,maghytec deep trans pan, a-pillar gauges and 5 inch exhaust
Yes please i need all the calids i can get.
What ambient temps are you guys having where you are when it happens?
Reason i ask, we had about 50degrees here this morning and the truck i have here, 07 4x4, auto, started up with no surges or hiccups, using the tow tune, it is going to be very hard for me to find this issue if can not replicate it.
Have all of you tried the tune alone (without stacking anything) and see if it gets better/worse or no difference.
Diablosport INC
Diablosport INC
I don't have anything stacked. And my truck doesn't do it the first start of the day....it was 26 this morning It's usually at lunch or after work. I don't envy you on this one........
CALID 35325551AQ
CALID 35325551AQ
Ok so you would say the motor is under normal operating conditions when it occurs?
Does a/c on off make it more pronounced? Or any other accessory turned on or off enhance or reduce it?
Diablosport INC
Diablosport INC
I wouldn't say normal operating temp, but not cold either. It has been setting a few hours. It ususlly does it when I start it the second time of the day. But it may skip 1 or 2 days. Once the rpm are above 1000 or so it is smooth....
However if it the idle is rough it will be like that until shut it off and re start it.
I don't have anything on but the radio
Arrgh, i have tried everything short of cutting the head off a chicken here and this truck will not surge.
Diablosport INC
Diablosport INC
I don't have anything stacked on my truck, and because I live in anchorage Alaska we've been having some extreme tempertures, it's been in the negatives for about 2weeks(-5 to -28 below). I'm not sure if this has an effect on it,but it diffenently idels funny. I normally pull it out of the garage and let it idle for about 15 to 20 minutes before I drive any where.Do you think maybe if I warm the truck up stock and then program it, will it help? I got the programmer this winter so I'm not sure if the weather is a factor. I do know that my superchip I got first has never done the rough idle and I ran it all winter last year.I'm not sure what to do !
