2016 Focus ST throttle issue
DiabloMatt
Re: 2016 Focus ST throttle issue
can you do me a favor and go to datalogging in the tool with it plugged into the car and you will get to a point where you can click "add pids" and see if you can manifold pressure? should be in there somewhere.
Will do ASAP. Thanks again. I would figure if I can add manifold pressure you would need a new set of logs, correct?
DiabloMatt
RZRSEDGE wrote:Will do ASAP. Thanks again. I would figure if I can add manifold pressure you would need a new set of logs, correct?
correct. i am gald you brought this to my attention. i was unaware the default pid list did not contain the boost perameters i needed. we are working on fixing this now.
i have another tune i want you to try but i want to be able to see what the boost is doing first
Sounds good. Will do as soon as we get the opportunity.
Thanks again,
George
Thanks again,
George
Third gear pull TC off.
Engine not braking as before.
Added Manifold Absolut Pressure, Turbo\super charger boost pressure and I believe it was manifold boost pressure to the PID list and logged. The MAP seemed to be stuck at 255 the whole time. The other two seemed to fluctuate with the boost though.
Matt is out this afternoon on an engineering mission, but he will go over these on Monday for sure.
Thanks!
Thanks!
Sounds good Mike. Thank you.
DiabloMatt
man...whats weird is i dont see anything out of the ordinary.
the throttle is wide open and at full boost by 2300-2400 rpm.
lets do one more thing. can you put the stock tune back in it and datalog the same exact thing so i can compare the two please?
Will do. May take a couple days; but I will post up the log as soon as possible.
Thanks again,
George
Thanks again,
George
Third gear pull with the stock tune.
Notice anything out of the ordinary?
Any updates?
DiabloMatt
one sec sorry
