adjustable parameters on 2016 challenger hellcat
aw148751
Re: adjustable parameters on 2016 challenger hellcat
Post by aw148751 »
Did I finally post it correctly?
sohfast94
Post by sohfast94 »
Do you have any other adjustments made? If so, that may be the issue of why the new ones aren't being added. Return to stock to reset the param cache and then try again. I've looked through the database multiple times and it's showing up so it should be showing up for you as well. This is the only reason it wouldn't be.
Insert Clever comment here...
sohfast94
Post by sohfast94 »
aw148751 wrote:Did I finally post it correctly?
Yep you did.
aw148751
Post by aw148751 »
I set everything back to stock and reloaded my backup tune. After that I just tried to modify the stock tune and there the fan setting is. Problem solved. Thanks for the help!
good to hear.
