update issues on mac..again
Post here with any questions regarding the use of the Ignition updater software for PC or Mac
Majvall
Re: update issues on mac..again
Post by Majvall »
I did try to connect it to Wifi (charg it with usb, not computer).
It was connected, but it said CONNECTION FAILD!
Then i tried to uppdate, but UPPDATE FAILD!
Can i realy trust this item and connect it to my Mercury?
Majvall wrote:I did try to connect it to Wifi (charg it with usb, not computer).
the wifi has no impact onthe performance of the device. Id suggest updating via usb for now.
Majvall
Post by Majvall »
Mikael!! Read at page one! I need an answere from you!
It feels like you avoid my problem. I cant use my Intune, and i need it right now!!
in an effort to resolve your issue, i would suggest connecting to a pc via usb and running the updater program, and the tool should be ok once its updated.
Majvall
Post by Majvall »
So i cant use my Apple any more?
bloemker76
Post by bloemker76 »
I just tried to update my I2030 on my mac, after the update it ask me to press "continue" to reboot the tuner. It gets stuck on the "please wait screen" and will not reboot. Help please.
Majvall
Post by Majvall »
bloemker76.
Its impossible to use Apple or Wifi. You have to use PC after the last update. :punisher: :normal:
Its solved my problem (exact same as yours).
/Peter
Macs just make it difficult as they dont allow the drive to eject. Manually ejecting it should resolve the issue, but a PC makes it much simpler.
Majvall
Post by Majvall »
Mikael. No it doesnt. Its impossible to use after you updated it via MacBook. I'd tried it even with USB and it doesn't work.
I solved it by using a PC. But it's still impossible to use wifi. Why?
the wifi has not changed, what happens when you try it?
Return to “Ignition updater”
