Page 2 of 2
Re: PCM Calibration update needed error
Posted: Fri Dec 23, 2016 11:08 am
by 06MonteSS
they're closed for Christmas holiday.. won't be back until Tuesday...
Technical Support
Telephone: 561-908-0040
Posted: Wed Feb 27, 2019 1:11 am
by rsalgado0520
Am having the same problem on my Jeep the dealer probably did an update too what do I do?
Posted: Fri Sep 13, 2019 3:10 pm
by Skullxminer
Bought a i1000 used got it unlocked and now i am getting the pcm calibration update needed error. what do i need to do????
Posted: Fri Sep 13, 2019 8:24 pm
by 06MonteSS
what is the year, model, engine of your vehicle????
Posted: Sun Feb 09, 2020 12:30 am
by ccbenn
Hello,
I have an I-1000 DCX. My tuner worked 2 days ago then I took it into the dealership for a new thermostat. Now, I get the message:
PCM calibration for 2C3CDXHG0DH571568 might need an update. Check for a calibration update?
Update manager says my tuner is up to date...but I just get the same msg again and again.
Help!
Posted: Mon Feb 10, 2020 10:27 am
posty the info.xml file from the intune drive please.
Posted: Mon Feb 10, 2020 8:00 pm
by ccbenn
info.xml file attached.
Thanks!
ccbenn
Posted: Tue Feb 11, 2020 4:42 pm
you didn't return it to stock prior to the dealer update, so the device needs to be reset.
give us a call with it powered up and reference that I asked you to call for a reset.
Posted: Tue Feb 11, 2020 6:01 pm
by ccbenn
Thanks Mike!
I'll call Wednesday morning.
Thanks again,
ccbenn
Posted: Sun May 03, 2020 12:12 pm
by mttsnb
Hi Mike,
My fuel pump failed and was towed to the dealer where they flashed the PCM. I am now having this same issue where it keeps telling me to do a calibration update but no update is found when I plug into the update agent. Attached is my info.xml. Can you help me get this solved?
Posted: Mon May 04, 2020 11:26 am
if you didn't restore prior to going to the dealer you'll need to call in and have the device reset first.
