I eventually found it. It was under Rev Limiter which I never looked at since I'm not adjusting the rev limiter!mikel wrote:under modify parameters in the advanced menu.lschafroth wrote:The new tank of fuel is much better. Less rough idle. I sped of the idle by 100rpms and that helped a lot.
I changed to Hard shift and that seems to match the Stock E85 shifting.
I could not find how to remove the top speed limiter. What menu is that under?
The idle is way, way better with fresh fuel. I did turn the idle rpm up 150rpms and it helps as well.
I found out I had only adjusted the shifting with the stock tune and not the Diablo Tune. I put on the Diablo Tune and the modify parameters for the shifting this morning.
I dont know if its me or not but the stock tune seems to be more powerful and responsive on E85 than the Diablo Tune is. Maybe its all in my head.
I'll drive with the Diablo Tune for a while and get used to it, then switch back to stock and see if I can tell.
Thanks for all the help!
Lannie
PS I will be getting a LewTune someday but that will have to wait a bit.
