Ignition Updates I2 Everytime I Run It/Wifi Never Enable
Post here with any questions regarding the use of the Ignition updater software for PC or Mac
chrisinAR
Re: Ignition Updates I2 Everytime I Run It/Wifi Never Enable
Post by chrisinAR »
Mine is doing the exact same thing. I tried to talk to tech support but they wouldn't/couldn't help.
HostileJava
Post by HostileJava »
Hi Mikel,
Any updates? It's been about a week since I tried the update, just wondering if I can get a status.
Avalanche 2500 8.1L Vortec/4L85E
HostileJava wrote:Hi Mikel,
please update again now and it will enable the wifi.
chrisinAR
Post by chrisinAR »
Mine keeps doing exactly the same thing. I have called Tech support and every person I talk to gives me a different answer. Mine keeps telling me the updater is missing.
chrisinAR wrote:Mine keeps doing exactly the same thing. I have called Tech support and every person I talk to gives me a different answer. Mine keeps telling me the updater is missing.
your device is fully up to date, no need to keep updating, not sure why thats happening but its not an issue as the tool is good to go.
chrisinAR
Post by chrisinAR »
I was able to catch this message.
chrisinAR wrote:I was able to catch this message.
if it is holding file sinthe tunes folder please post them here or email them to me.
chrisinAR
Post by chrisinAR »
Mike,
My email is [email protected]. I couldn't figure out how to email you. I several tunes that I don't want to share on here.
retiredtechnician
Post by retiredtechnician »
I'm having a very difficult time trying to agree that "its not an issue ":
1. You have told several of us that our unit is not up-to-date after doing multiple updates.
2. It doesn't just affect one unit, but multiple units.
3. Diablo was notified of this problem back in April and it's still doesn't work correctly.
4. As far as I know, there is no other way to tell if it's updated other than sending you the info file every time.
Is it possible to update via the old way? That seemed to work.
Here's my info file again. Please help.
RT
HostileJava
Thanks! Mine is now showing the WIFI enabled, although I haven't tested it yet and no longer continues to tell me I have an update every time I run the Ignition software.
retiredtechnician
Can somebody help me here?? This was first reported almost a month ago and it still doesn't work.
This is not an isolated case; there are at least two more threads here that describe the same problem:
May 26th post at: https://forum.diablosport.com/viewtopic ... 63&t=63884
First post at: https://forum.diablosport.com/viewtopic ... 90#p334090
I tried to help you by isolating the problem. I've tried it on two different computers with two different Windows operating systems, both with the same results ... it doesn't work. It appears the problem lies with either the 'Ignition' software or the i2 unit.
Can you at least tell me if my unit is up to date? Or, better yet, will you explain to us how we can determine if it's up to date? I tried it again tonight with the same results. Here's my info file.
You haven't addressed this as a problem in any of the three threads. Why?
RT
mike1976
Post by mike1976 »
If i update then turn off plug back in says update aval every time
retiredtechnician wrote:Can somebody help me here?? This was first reported almost a month ago and it still doesn't work.
RT
this was up to date when you posted it, there is one newer update available now.
Return to “Ignition updater”
