2018 F-150 EB 10 Speed
cjonesth
Re: 2018 F-150 EB 10 Speed
Post by cjonesth »
Mike now that we have the tuning capability, when will we have the ability to Calibrate Speedo for Tire Size, Calibrate Speedometer for Gear Ratio, select a cold air intake as well as other mods on the i3 when selecting a tune?
2021 Ford F150 SC XLT 3.5 EB Sport Fully Loaded
I3 and Predator P2 Platinum
tire and gear should be there now....
cjonesth
Post by cjonesth »
Mike I checked again this morning, after selecting the tune I selected Modify Parameter then Select Parameter Control Unit to Modify. There was nothing there to select or modify under Select Parameter Control UNit to Modify, it is blank. I have updated the i3 and every time I connect to the Ignition Updater now it tells me there are updates available. I select update and it downloads files 4/5 and 5/5. I connect to the vehicle and get the same thing, no parameters to modify. Current Rev. on my i3 r116 (2files)
Just to let you know I purchase another licence for my i3, the first vehicle is a 2016 Mustang and the licence I purchased yesterday is for my 2018 F150 Lariat 3.5 EB
OK, so you are getting no parameters at all. I will look into this.
cjonesth
Post by cjonesth »
That is correct no parameters.
cjonesth
Post by cjonesth »
Mike what is the status on not seeing any parameters to modify?
they are looking into it, should be a fix soon.
Do you need something adjusted for now that I can do for you in a custom tune maybe?
cjonesth
Post by cjonesth »
I should be good until they get a fix for it.
cjonesth
Post by cjonesth »
mikel wrote:they are looking into it, should be a fix soon.
Mike can you do a custom tune for the 87 Octane tune for the 2018 F150 3. EB. Tire size 33.5", rear axle 3.55 and also have a cold air intake installed?
cjonesth
Post by cjonesth »
Mike since I loaded the tune for the subject vehicle my electric tailgate opener doesn't work, I returned the truck to stock and the tailgate auto opener still doesn't work. Not sure if it is related to loading the 87 Octane tune. Will have the dealer look at it and let you know. How are they doing for the modified parameters being fixed so they show on the i3?
cjonesth
Post by cjonesth »
Went to the dealer today, they figure it is the electric motor in the rear tailgate that is causing the problem. They have ordered a new motor and when I left the dealer I reinstalled the tune.
cjonesth
Post by cjonesth »
Mike any update on this issue?
cjonesth
Post by cjonesth »
mikel wrote:OK, so you are getting no parameters at all. I will look into this.
OK so after I had the truck at the dealer, I removed the tune and restored to OEM. I decided to use easy tune and selected 87 Octane. It asked me if I wanted to modify the tires I said yes, it asked me to modify the rear axle ratio I said yes and it then asked me if I wanted to remove the limiter and I said yes. It wouldn't install the tune, not sure exactly what the error said. I had to use advance tune and selected the same items to modify. There was nothing to select on each parameter but it did load the tune. Any update on this, This is very frustrating and not getting any updates? :roll: :x :cry:
cjonesth
Post by cjonesth »
Mike any updates on the fix for my i3? :( :evil: :roll:
cjonesth
Post by cjonesth »
Mike what is the hold up? Is this a case of rushing a product to market that is not completely 100%?
