Page 2 of 3
Re: RE: Re: RE: Re: RE: Which Thermostat runs best with the
Posted: Sun May 04, 2008 2:58 pm
by Quick
Mike_Levy wrote:Oil temp and engine temp are completely different. You can keep the fans on their 180 setting and still get the oil temps up. Water boils at 212 so thats what you need to get the oil temp upto to burn off any condensation.
Yes, completely different but related to engine/coolant temp. (crap, I watched that pretty closely some time ago and now I've completely forgotten). I guess they could be pretty different with oil coolers and whatnot. I have the impression that it's good to get your oil up above some minimum operating temp (maybe not critical). Water vaporizes more the hotter it gets right? And then there's other stuff/contaminates that come off it right? I don't know much about oil (but I slept at the Holiday Inn last night, haha). I do send a sample for analysis to Blackstone every time I get the oil changed. http://www.blackstone-labs.com/
Re: RE: Re: RE: Which Thermostat runs best with the Predator
Posted: Mon May 05, 2008 12:44 pm
by BlueSunshine
SRT8Tech wrote:
BlueSunshine wrote:Thank you Mike and Quick, I am cancelling my order for the TB Spacer(No it was not the Turbonator) and I am having the Valucraft 4128 Tstat installed at Jacksonville Dodge right now, that I picked up from Autozone last night. The guy at the shop that I purchased the PREDATOR from says he has installed TB on other 6.1's and 5.7's and he said it made a difference and didn't want me to cancel my order, and kept on trying to sell me on the "IDEA" behind the TB Spacer(He lost, that is why Jacksonville Dodge is putting on my Tstat right now and he is not). Another question is what temp should I change my temp settings to on the PREDATOR?
LOL, I worked a Jax dodge when they first opened. It WAS a nice shop until the A$$holes took over. Do you know the tech putting the t-stat in??
His name was Anthony. Is he pretty good or should I change?
RE: Re: RE: Re: RE: Which Thermostat runs best with the Pred
Posted: Mon May 05, 2008 12:55 pm
by BlueSunshine
I wanted to Thank everyone again for your help. Taking off K&N Typhoon and I am changing to the AFE Magnum FORCE Stage 2 Cold Air Intake System tonight!! :D Quick the numbers you gave me seem to work perfect on mine, Thanks Again!!
Posted: Thu May 08, 2008 7:52 pm
by BlueSunshine
I installed the AFE and can not believe the difference it made over the K&N. The feel and the sound are awesome!!!
Posted: Fri May 09, 2008 3:09 pm
by Chargeron24s
I had the 4128 but now im installing the 4127 176 degree T-Stat, anyone know what fan settings to use for this?
Posted: Tue May 13, 2008 11:38 pm
by angrygnat
gsjoe wrote:Do you need to drain out some coolant when installing the stat?
Can it be done with minimal loss of coolant and switched back easily for trips verses the track?
I actually do this with a lopped off milk jug, just squeze it in under the t-stat housing before loosening the bolts... don't take the cap off the overflow bottle or you'll have a real mess on your hands (how do I know that?)
Posted: Wed Aug 27, 2008 9:03 am
by whatever_weirdo
Quick wrote:My t-stat opens at 185*. Everyone refers to a "180*" t-stat. I have a 4128 Motorad which I purchased at AutoZone (I think maybe they call it Valucraft but when you take it out of the box it's stamped 4128 Motorad). If I'm going down the highway when it's relatively cool out my temp stays at 186* or 187*.
When you set the fans it's for the fan ON temp. Once the fans kick on they will run until the temp drops some amount below the turn on temperature. With my car it seems to be about 3*. If I set my fans at 181/184 the HS fans would run all the time. By the way. We have 2 fans. I think on low speed the fans are run in series and on high speed the fans are run in parallel? We don't have a mid speed. So I have my fans set to keep the temps about 190 or less most of the time. It hasn't got really hot here yet. I haven't really seen anything over 194 and I don't think my HS fans have ever kicked on.
I believe the PCM will start pulling timing somewhere over 190* and a significant amount of timing over 200*. I believe you really need to get your oil temps up over 190 or so to flash off condensation and other stuff. So I get a little over and every couple of weeks I set them to stock and it will go up over 200 in city traffic. I'm just kind of thinking the fans aren't designed to run constantly. In any event the HS fans are kind of noisy. Haha, I guess the bottom line is I don't have any really concrete reasons.
well as all will tell you id keep the water temp at 190 on the predator when using a 180* t-stat cause the longer the fans run the quicker the fans burn out
my 2 cents
mike
RE: Re: RE: Re: RE: Re: RE: Which Thermostat runs best with
Posted: Wed Aug 27, 2008 3:14 pm
by Mike_Levy
The fans are rated for a crazy amount of hours. They can run constantly and will probably still last for 5-6 years at least.
Re: RE: Re: RE: Re: RE: Re: RE: Which Thermostat runs best w
Posted: Wed Aug 27, 2008 7:08 pm
by ZMagnum
Mike_Levy wrote:The fans are rated for a crazy amount of hours. They can run constantly and will probably still last for 5-6 years at least.
That's what I've heard. That they would outlast the engine. People have had fans replaced for failure though but why they failed I don't know.
I assume that the fans spin when you drive and enough air passes over them. If that's the case they are spinning all the time even when off.
RE: Re: RE: Re: RE: Re: RE: Re: RE: Which Thermostat runs be
Posted: Wed Aug 27, 2008 8:06 pm
by Quick
Some of us find it very annoying to hear their fans running all the time :)
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Which Thermostat run
Posted: Wed Aug 27, 2008 11:39 pm
by ZMagnum
Quick wrote:Some of us find it very annoying to hear their fans running all the time :)
You will find it even more annoying when I pass you because my engine is running cooler than yours. :lol:
Posted: Thu Aug 28, 2008 12:29 am
by Quick
Haha. That's always a risk for those unexpected encounters...
Posted: Tue Sep 02, 2008 4:10 pm
by MikeEast
Is there any way to actually see the oil temperature?
I have a ported-n-polished 6.1 oil pump on my 5.7 that give me all sorts of oil pressure, but nothing so far in either the EVIC or the Dashawk gives a hint as to oil temp.
Thoughts?
Mike
Posted: Tue Sep 02, 2008 4:18 pm
by Mike_Levy
The LX EVIC does show oil temperature.
Posted: Tue Sep 02, 2008 4:46 pm
by MikeEast
Mike_Levy wrote:The LX EVIC does show oil temperature.
Maybe yours does, but all I see is oil pressure (number and graph, separate places) and 'Eng Temp' which I'll have to go with 'coolant temp'.
05 Magnum RT, slightly mod'd, 10/04 build.
Mike
