2019 RAM 5.7 / I3 Swapped unlocked PCM
Maverick612
Re: 2019 RAM 5.7 / I3 Swapped unlocked PCM
Post by Maverick612 »
MDS now programs. Inwiould like| to list some bugs
1 ecu not supported still there, guess trans support not here yet.
2 thrott)e boost doesn't seem to do much or anything.
3 93 program shows up in quick tune but is not on the list in advanced.
4 If you drop the in park ilde and then slightly raise the rpm with the pedal, say from 700 to 1000. The truck will sugee say from 6ⁿ0 to 1300.
Please post the info.xml file from the i3 drive so I can check out the tcm cal.
Id also like to see the file in the tunes folder so we can see the throttle boost adjustments.
The 93 tune is listed as Diablo tune in the advanced menu.
Maverick1
Post by Maverick1 »
Per your request info and last written files. BTW, throttle was save at +20. RPM lowered 200 in Park only. And Yes an error that some ECU's are not supported.
Regards,
Latest updater error in ignition. "Unsupported file for your calibration not found." 7/18/2019 Says update is available.
2019 Ram Laramie Longhorn 1500 5.7 392 rear ends, new style.
8-Speed
All available options
Unlocked pcm and I3 Diablo Tune
Magnaflow catback system
K&N cold air intake.
