P0601 code after new calibration update
lkoroush
Re: P0601 code after new calibration update
Post by lkoroush »
mikel wrote:OK, this one is fixed.
I should be able to do this all automatically.
1. return vehicle to stock/original backup
2. Update device, it should force it to do a calibration update
3. Go to vehicle and click tune menu and it should prompt to go back and check for an update.
4. Update again to download the new updated stock file
5. Load it to the vehicle through the tune menu, no more code.
couple minutes after starting up and idle it thru P0601
doesnt sound like it did the cal update.
Please give us a call with the device powered up in the truck and we'll force the cal update with you.
lkoroush
Post by lkoroush »
no after the last update i tried to connect to wifi and not it freezes for a couple minute then it has blank list of wifi networks
theres a wifi bug were working on, please use a pc and update agent for now if possible.
lkoroush
Post by lkoroush »
mikel wrote:theres a wifi bug were working on, please use a pc and update agent for now if possible.
okay are you able to force cal update with it plugged into laptop and running update agent?
yes if you update now it should trigger the cal update.
lkoroush
Post by lkoroush »
So I've still been waiting for the fix for some time now and it's only gotten worse, that p0601 code isn't fixable I've talked to shops and they said it's a bad pcm, which make sense why it's got worse, only had the PCM for 5-6 months supplied from you with the i3 platinum and pcm swap and really wish you would have had good customer service and had just swapped me for a good one now truck had to get towed and have more then likely have to buy a new pcm to replace the bad one your company sent me.
