Transmission modes?
Quick
Re: RE: Transmission modes?
Post by Quick »
08stonedcharger wrote:Do you really have to respond to everyones post? You are not an employee of Diablo Sport and you probably don't have any formal training on the tuner other that playing around with yours. Please let the Professionals respond and keep you suggestions to yourself. There are plenty of LX forums for you to share your recomendations on. I come here for help from the pros ONLY!!!
I'm sorry. You didn't specify you only wanted your answer from DiabloSport personel. If you haven't noticed it's an open forum where everybody kind of trys to help everybody else wiith the repetitive questions. If you want your answers only from DiabloSport personel then address your questions specifically to DiabloSport personel. They are active on the forum and will jump in to correct misinformation when needed or answer unanswered questions. Believe me, my throwing in my completely uninformaed wild ass guess won't preclude your getting an answer from the professionals. I'm sure Mikel or Johan or somebody will take care of you.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
08stonedcharger
Post by 08stonedcharger »
I'm sorry I ripped on you so hard! I was just so pissed and I wanted concrete answers. I freaked out when my car started acting up at the track and all I want is a do not mess with list from Diablo.
whatever_weirdo
Post by whatever_weirdo »
johan wrote:^^^--- what he said.
Mode 1 should work fine on the 06 srt8's
i have a 2006 300c 5.7 and i only have stock mode 1 mode 2 and i tryed both and it still shifts for me i have 9r04 did i kill my predator everything else works fine
CaptainJ
RE: Re: RE: Transmission modes?
Post by CaptainJ »
FYI: On a 06 RT Mode 1 and Mode 2 disengage the transmission at red line. None of the modes but stock up-shift now.
2006 Dodge Charger R/T, CAI, 185 T-Stat, 85MM T-Body, NOESP, BT Oil Catch Can, exhaust.
PreadatorU7135
SN 225583
V.9r12
Jected
Post by Jected »
Was going to say thats the first time I have seen anyone have a go at someone for trying to help out. Way to sort it out in the end mate.
As for the ESP diabling through Predator, it is not necessary and should not be done. It is for use as a tuning mainly - dyno etc. The problem with disabling it is that the car will still sense yaw rates and at a certain degree/angle the car will go into limp mode. At the track it is not needed. Most guys I know who have run 11.50's and better just disable at the dash.
07 300C SRT8
RDP built 426/RDP-Bullet/Harrop supercharger(Boost 20psi)/HP/F custom fuel &Intercooler system/Nitrous setup/DSS 1000hp Half Shafts/Kooks Headers/Zoomers cat back/Precision Industries 3200
05MAGNUMRT
Post by 05MAGNUMRT »
If you want a straight answer from DS right away, call them!
As these guys have correctly pointed out, ESP disable is not something we recommend for the street.
It usually will not cause issues at the track going in a straight line, but thats up to you.
FYI, next revision ESP disable will be renamed 'dyno mode' in the Predator.
CaptainJ
Re: RE: Re: RE: Transmission modes?
Post by CaptainJ »
CaptainJ wrote:FYI: On a 06 RT Mode 1 and Mode 2 disengage the transmission at red line. None of the modes but stock up-shift now.
So is there a Mode that will still allow auto up shifts that is not stock for a 06 R/T Charger?
PreadatorU7135
SN 225583
V.9r12
05MAGNUMRT
That sucks, that what mine did in Mode 1, then I tried mode 2 and it was like Superchips Paddle kick mode, it increased shift point rpm and it shifted automatically at redline and it gave me the "5" that many lost with Predator.
I guess mode 2 working like Paddle kick only works on the 05 models, I get no mode 3 by the way, don't you 06-08 guys have mode 3?, if so, have you tried it to see what it does?
CaptainJ
RE: Re: RE: Re: RE: Transmission modes?
Post by CaptainJ »
I only have Stock, Mode 1, and Mode 2. If I am supposed to have a Mode 3 that might be the problem. I have the latest software so I am not sure what to do at this point.
PreadatorU7135
SN 225583
V.9r12
05MAGNUMRT
Re: RE: Re: RE: Re: RE: Transmission modes?
CaptainJ wrote:I only have Stock, Mode 1, and Mode 2. If I am supposed to have a Mode 3 that might be the problem. I have the latest software so I am not sure what to do at this point.
Call them and talk to them, they'll know what's going on, you can ask them how may modes your 06 is supposed to have, and see what each mode does, you have to load each mode into your car and see what they do, nothing beats real world testing.
CaptainJ
RE: Re: RE: Re: RE: Re: RE: Transmission modes?
Post by CaptainJ »
I loaded each mode and they all disengage the tyranny at red line except for the stock mode.
PreadatorU7135
SN 225583
V.9r12
bob34787
Post by bob34787 »
05, 06 and 07 will only have mode 1 and mode 2 and stock. Mode 3 was for 08 and above and will not show up on your screen unless you have an 08
I don't have any modes. They can't crack the tranny in the Jeep. :(
CaptainJ
Post by CaptainJ »
So am I the only one then that Mode 1 and Mode 2 will not auto up shift?
PreadatorU7135
SN 225583
V.9r12
