Bugs
Re: Bugs
not yet... i couldnt get on the forum all day but i have a patch for you, give me a minute345WK2 wrote:I just ran the updater and it installed the r300 package. I guess I'l get off my couch and go check it out. Ill post if anything changed, otherwise, no news is still bad news. lol
Re: Bugs
ok new update is ready to fix the adding pid stuff.
Re: Bugs
awesome. Just to confirm, you are back to being able to add pids properly?
Thakns
Thakns
Re: Bugs
The I3 I have still wont add PID's after the last update yesterday - I3 Snr. 201509154.
I have tried many combinations of clearing out the whole PID list.
Then adding new ones, that does not work. When I go to record log it will be completely empty (from when I deleted the PID's before)
I also tried just adding a few to the default list, still wont work.
It will datalog the default PID's fine also remove PID's
I attached the latest XML file and zip of runtime folder
Re: Bugs
I was able to add ST KR and LT KR. Haven't had much time to add any others but they definitely worked for sure on mine after the update yesterday r300 r33 I think it was.
EDIT: I just went out and verified that everything is working on mine as it should. Live view and Record are both showing the PIDs that I add to the list.
Re: Bugs
pbl2020 wrote:The I3 I have still wont add PID's after the last update yesterday - I3 Snr. 201509154.
That what mine was doing but at about 4pm central time they sent out an update that seemes to have cleared up all of my issues. Odd that it wouldn't fix yours also.
Re: Bugs
its a patch that needs to be applied for now, I targeted your device, please update and it will be fixed.
Re: Bugs
awesome. We'll get this set live for everyone asap.
Re: Bugs
please update to get the fix for adding pids, new dv will be coming soon to fix analog playback.killface wrote:I'm having the same issues as far as not being able to add parameters to be recorded, not letting me even attempt live view, and my i3 no longer recognizes my 5v analog input signal.
Re: Bugs
I am having the highlighted issue...Is there a fix yet?mikel wrote:there was a major update that went out, mostly to address new features and functions on the T2. i2/i3 share most all of the same applications as T2, so they got updated as well.
We tested the heck out of these updates but there's always something that slips through.
The logging issues have already been corrected and fixes are set current.
The wifi menu is still not showing networks but there's a fix being tested for that now and i expect to have it available this week
