Page 2 of 3
Re: Upgraded for inTune i3 to newest Trinity
Posted: Tue Jan 11, 2022 12:25 pm
by dadrainer
mikel wrote: Tue Jan 11, 2022 11:59 am
i expect the tool to be asking for anb update where it will request a stock file from our server, but its not there.
Im going to reset it. Please update once then try tuning it again. If it still says its previously tuned, update it again the try tuning after that.
Thank you for your assistance.
Do you want me to put the unlocked PCM in the car and then re-tune? Is there anything I need to do after you reset it? Do you need me to add files to Trinity?
Posted: Tue Jan 11, 2022 12:29 pm
by dadrainer
Also, which ignition account should I be using? One of them completely locks me out and the other one works to appoint.
Posted: Tue Jan 11, 2022 2:58 pm
yes, you have to have the unlocked pcm in place to do anything....
It shouldnt matter which account you use really.
Posted: Wed Jan 12, 2022 6:56 pm
by dadrainer
Here's the play by play...
Tried to use original Ignition account…didn’t work….unrecognized device, so I then used the more recently downloaded Ignition.
6 files to update…it was slow to download file 10/11
Files installed onto device
Ignition screen said device is up to date, but didn't show "featured downloads"
Unplugged device from computer
Plugged into car with unlocked PCM, tuned to 91 octane, device said it’s been tuned before with a different device. Unplugged device from car as per the device.
Plugged device back into computer, ran Ignition, says there are updates
Hit “yes” to update but Ignition says “Attention” Unsupported File for your calibration not found. Please contact tech support”.
I hit continue and it downloaded a file onto the device. Device restarted automatically. Ignition screen went white, then said that device is now up to date. Device screen returned to start screen.
Unplugged from computer and plugged it back into car.
Followed all screen prompts
Hit “tune” button…read stock file..then got “PCM has been tuned before by a Diablosport product”. I hit the ‘continue’ button. Then got “please disconnect the t2 from the vehicle at this time. Connect the t2 to a pc with internet access and run the updater application. I hit ‘continue’ and get “one of the ECU’s in the vehicle has been previously tuned with a tuning device. Please restore it to stock condition and then begin anew”.
I plugged the device back into the computer and started Ignition. It says there are updates available, etc. I hit “yes”. which said, and goes back into the “unsupported file for your calibration not found. Please contact tech support” I hit continue and it downloaded a file onto the device. Device restarted automatically. Ignition screen went white then said that device is now up to date. Device screen returned to start screen.
That’s where I’m at. Attached is the info.xml file
Posted: Fri Jan 14, 2022 11:37 am
save the attached file to the i2 drive and let it import the file, then go to the vehicle and it will prompt you to load this in the tune menu.
Once loaded its back to stock and you can retune.
Posted: Sun Jan 16, 2022 7:49 pm
by dadrainer
I think we are in business! I did what ya said and then did an update after that. Plugged 'er back into the car and was able to restore back to stock.
Many thanks and cheers! Now, I have to do an O2 sensor job. Once I complete that, I'll give it a nice tune!
Posted: Mon Jan 17, 2022 12:24 pm
glad to hear it, enjoy.
Posted: Thu May 25, 2023 2:12 pm
by Flopez27
I have a 2021 dodge Durango rt AWD. I just purchased the Diablo tune. The current mods I have on my Durango is: AFE cold air intake, msd ignition coils, bbk 85 mm throttle body, pedal commander, and corsa catback exhaust. I have a granetelli 185 deg thermostat and want to install it. Would the regular 93 tune support the thermostat or would it have to be a custom tune? Let me know thanks
Posted: Wed May 31, 2023 11:01 am
you can use the device to adjust the target cooling fan temp and lower it about 15* from where its set now.
Posted: Sun Jul 23, 2023 11:38 pm
by Sgarbet
Having a similar issue to the original poster, had and i3, now stolen, purchased a new one but giving me errors when trying to “re-tune” the truck I Hit “tune" button... read stock file. then got "PCM has been tuned before by a Diablosport product". I hit the continue button. Then got "please disconnect the i3 from the vehicle at this time. Connect the i3 to a pc with internet access and run the updater application. I hit
'continue' and get "one of the ECU's in the vehicle has been previously tuned with a tuning device. Please restore it to stock condition and then begin anew". Issue is I have a Mac the the “ignition” program does not run. Any ideas?
Posted: Mon Jul 24, 2023 11:36 am
Sgarbet wrote: Sun Jul 23, 2023 11:38 pm
Getting ignition running will certainly resolve this, for now post your info.xml file from the t2 drive here and I will get you going.
Posted: Mon Jul 24, 2023 2:38 pm
by Sgarbet
mikel wrote: Mon Jul 24, 2023 11:36 am
Ive attached the file I think, also how do i get ignition working on a Mac? i believe its been an issue for a while that hasn't been addressed
Posted: Mon Jul 24, 2023 2:58 pm
Sgarbet wrote: Mon Jul 24, 2023 2:38 pm
Your mac likely needs to be on the latest OS for it to work, thats the most common issue we see. if thats not it, give our support team a call to try to sort it out please, 561-908-0040.
Posted: Mon Jul 24, 2023 3:01 pm
save the attached file to the t2 drive and let it import the file then go to the vehicle and select the tune menu and it will prompt you to load this update to set the pcm back to stock, then you can tune it.
Posted: Mon Jul 24, 2023 9:42 pm
by Sgarbet
mikel wrote: Mon Jul 24, 2023 3:01 pm
Sorry what is the t2 drive? is that for a trinity? i have an i3. The folders i have are logs, ready, runtime, tunes and updater
