05 Magnum R T
Discuss Predator 2 for Chrysler vehicles
Karp
Re: 05 Magnum R T
Post by Karp »
And yes it is highlighted when I return
Karp
Re: 05 Magnum R T
Post by Karp »
Karp
Re: 05 Magnum R T
Post by Karp »
Device serial #202173126
Re: 05 Magnum R T
Karp wrote: Thu Jul 06, 2023 3:09 pm And yes it is highlighted when I return
this tells me it thinks it programmed to 3.07. Are you 110% sure the gears you installed are 3.06? Like you verified driveshaft revolutions, or similar?
Karp
Re: 05 Magnum R T
Post by Karp »
Yes
Re: 05 Magnum R T
if you program it to a different ratio, does the behavior change at all?
or the speedo?
Karp
Re: 05 Magnum R T
Post by Karp »
No
Karp
Re: 05 Magnum R T
Post by Karp »
I have tried just about everything I can. Even transfer case ratio. No love
Re: 05 Magnum R T
OK, tough spot here. I am not convinced that the P2 is not working. You could try swapping it out for an i3, as it handles this stuff differently. You could also look into upgrading to an EGS53 style TCM, which will likely help. you could also get the TCM pre-programmed for any gear so you don't have to do it yourself.
Karp
Re: 05 Magnum R T
Post by Karp »
Ok, what do I have to do to swap it for the i3
Karp
Re: 05 Magnum R T
Post by Karp »
And thank you
Karp
Re: 05 Magnum R T
Post by Karp »
And where do I get the EGS53
Re: 05 Magnum R T
Karp wrote: Fri Jul 07, 2023 3:23 pm Ok, what do I have to do to swap it for the i3
give us a call, 561-908-0040
Re: 05 Magnum R T
Karp wrote: Fri Jul 07, 2023 3:37 pm And where do I get the EGS53
shop around for a mopar TCM or check with hemituner and see if he still offers his programmed versions.
Karp
Re: 05 Magnum R T
Post by Karp »
Thanks, I have one coming from Hemituner. What about updating my p2 for the i3?
Return to “Predator 2 for Chrysler/Dodge/Jeep/Ram”
