Page 11 of 17
RE: Re: RE: just purchased my u7192
Posted: Sat Nov 21, 2009 12:16 am
by 06MonteSS
have you gotten your fueling adjusted correctly yet??
that will give you more throttle response, better acceleration, stronger/harder pull, and better mileage to boot!
here's info:
Posted: Wed Nov 25, 2009 10:05 am
by keith2006
Hi i was just curious if there is a way to check the status on a programmer that was sent in for a hardware upgrade? If not is there a way to see when they ship it?
Thanks Matt
Posted: Wed Nov 25, 2009 10:13 am
by 06MonteSS
shoot an email to [email protected]
Posted: Wed Nov 25, 2009 10:29 pm
by keith2006
Okay.
Thank you
Posted: Wed Dec 09, 2009 4:38 pm
by james2003
OK, just got back my U7193 from Diablo. (had it upgraded). The tool lets me go through all the steps to modify tune, but when I go to install it, it gets to 4-5% then gives me an "unknown error ()" message. In the tool menu, it doesnt show anything for hardware or Bus, and shows the Bus as untested. What gives? $115 is a lot to spend on something that doesnt work. 2003 Silverado 5.3.
Also, after trying to install, I am getting a "Service Brake Booster" message.
Posted: Thu Dec 10, 2009 9:43 am
by james2003
The "service brake booster" message went away. Called tech support cause the tool read "Illegal Programing" when I tried again. Made sure to unplug the fuses and such, still not working. Keep getting "Unknown Error". Im gonna try another Predator to see if the upgraded one is just crap.
Posted: Thu Dec 10, 2009 10:19 am
by james2003
OK, just checked...my upgrade is crap. I have a U7193 for my lifted 2005 Silverado. Put it back to stock and ran that predator on my 2003, worked like a charm. Tried to use my "Upgraded" predator in my 2005, did not work, "Unknown Error" again. Which is crappy because before the "upgrade" I could at least use it on the 2005. So now Ive spent about $115 for an upgrade that doesnt work. Any help?
Posted: Mon Dec 21, 2009 1:55 am
by karlmeyerholt
i have a u7194 i bought for my 07 chevy new body style truck i lost truck to a fire i bought a 06 gmc serria with a 4.8l the list calls for a u7192 is their a rom or somting i can dolwnload to the tool to program the new/used truck
Posted: Mon Dec 21, 2009 9:25 am
by 06MonteSS
no... the PCM's are different... you can not make the 7194 work on the 06 gmc... you'll need to buy the correct predator for that 06 truck...
Posted: Thu Feb 11, 2010 12:03 pm
by kblo04
I installed programmer and was faster but when I installed cold air intake & body spacer i lost time why is that
Posted: Thu Feb 11, 2010 12:20 pm
by 06MonteSS
because now you introduced more air intake/flow, so you have to get your fueling re-adjusted now...
do some logging and get your fuel trims dialed in...
here's info:
Posted: Sun May 02, 2010 12:15 pm
by RidinHighChevy
Hi Mike, I have a 2004 chevy 2500HD and am using the U7193, are there any upgrade avaliable for me so I can set the program for the exhaust and intake I have on the 6.0L motor? Also, can i download the udates and if so, how do I do it?
Regards,
Mike
Posted: Tue May 04, 2010 9:20 am
by 06MonteSS
what revision is that 7193 on? when it's at the main menu, there's a number at the top of the screen... that's the revision number... what is it?
U7191 upgrade
Posted: Wed May 05, 2010 5:15 am
by jswhigham
Is there a hardware upgrade for the U7191 rev 7R99 ?
RE: U7191 upgrade
Posted: Wed May 05, 2010 8:17 am
by 06MonteSS
wow, that's old... don't use it on your vehicle until you update it...
no, no hardware upgrade needed... you can download the new crom revision update, and update the predator yourself to the latest version.
the crom revision update file, and dsdownloader program you'll need can be found here, along with revision update instructions:
http://diablosport.com/index.php?module ... lay&pid=68
