Posted: Wed Sep 30, 2009 10:43 pm
so is the 9r17 update the new crom we've been trying out?
Diablosport Forums
https://forum.diablosport.com/
I have an AEM wideband UEGO. My afr's hit 12.4 today cuz of the cold weather, higher boost i guess. I logged with the map today. I turned down my boost after this log and added another 3% of fuel to each rpm range. I will dl this new addition tomorrow. But here is the one I did today.duster360 wrote:First things first, log the proper PIDs. You didn't log the most important PID, MAP. Without it you don't even know what your boost is.Srt4Dr1ver wrote: So I ran the tune again, without pulling any timing, just added fuel, my max hit afr was 12.2, a little high but I will lower it tomorrow. But as to my knock, it still is ridiculously high. What do I need to do for this to work...? Here is my log.
Here's my suggested list: http://www.srtforums.com/forums/f384/wh ... og-484265/
Second: That's quite a bit of knock for a max A/F of 12.2 and relatively low timing especially with Don's new Knock thresholds. Somethings up. Add fuel back in to get the A/F between 11.5-12.0, clear the LT KR and retest. A more complete list of PIDs might show an issue.
Are you using 91 octane fuel or 93?
Do you have a way to datalog A/F?
What brand of wideband are you using?
My car is in the shop right now, something with my clutch or trans, it's making weird sounds. I will try to do another run with everything you have listed as soon as I get it back.duster360 wrote:Get the A/F under 12.0 before you do anything else.
Log as many PIDs on the list i provided as you can.
OPen Loop Fa
LT fuel trim
St fuel trim
These and most of the others are very important and should be logged every time
1st: email Don for this improved 93 tune. Most of your knock will probably go away.BlackACR wrote:For those of us running the DSP and not yet having a Wideband, should we be concerned with running lean being we can't see what the A/F is? I've had 6* pulled due to knock, and I'm spiking to 22 or so psi dropping off to around 15psi. I've pulled timing to rid of knock but I still don't know what my A/F is. I was adding fuel while pulling timing as well (added about 6-7% from 3-7K RPM) I was originaly under the impression this was a pretty safe tune to run but I'm not too sure now. Thanks guys *Mods list below.
Srt4Dr1ver wrote:I have an AEM wideband UEGO. My afr's hit 12.4 today cuz of the cold weather, higher boost i guess. I logged with the map today. I turned down my boost after this log and added another 3% of fuel to each rpm range. I will dl this new addition tomorrow. But here is the one I did today.duster360 wrote:First things first, log the proper PIDs. You didn't log the most important PID, MAP. Without it you don't even know what your boost is.Srt4Dr1ver wrote: So I ran the tune again, without pulling any timing, just added fuel, my max hit afr was 12.2, a little high but I will lower it tomorrow. But as to my knock, it still is ridiculously high. What do I need to do for this to work...? Here is my log.
So I ran a dl again today but with lowered boost and more fuel. My fuel is +~12% in each rpm range. I ran it in 3rd gear and my boost was at ~15psi and creeping maybe to 16. I wanted it to be ~18-19 but I guess I went too low. I didn't get a chance to run again after raising it up some but here is my datalog.
Fuel: +~12%
Boost: ~15-16psi
AFR: mid 10's
I'm hoping with my goal 18-19psi that my afr's will be mid 11's.
BTW: I put in new NGK 4306's gapped @ .32. Before I was stock champions gapped @ .50. That might've been a problem.
-93 octane btw.
What are the a/f's like w/o the changes made?Krazyrdr83 wrote:Ok, Duster or Don, help me out here.
Car has been running pretty good. Duster, you mentioned the 93 oct tune (9r18 crom), was pulling 2% LT fuel, so I pulled the negative cable off last night for about an hour while I got ready to go out. Didn't do any pulls last night, this morning I added fuel (was running 11.8-11.9, thought I would bring it down a little). 12.5% 3-4k, 12.5% 4-5k, 12% 5-6k, 11.5% 6-7k (as of right now).
Did a pull this morning 3rd-4th, temps are prob 10 degrees cooler than the last time I showed you my log, a/f are stuck in the 12.0-12.2, sometimes drop to 11.9. Before, I would only add 10% and run high 10's mid low 11's. But seems as if lately with the 93oct tune it's running a bit leaner, and having to add more fuel. AS for fuel mods, stock PCM, stock fuel system, fuel pump rewire. Also, while looking at the graph, seems like LT fuel is still -4%, before it was -2%.
I'm not getting any knock besides the high rpm of maybe 1 count. LT knock comes and goes, but can't pinpoint where it's at, again it's only 1 count. Any input and suggestions would be helpfull. Spike hasn't changed, 20-21 psi and drops down to about 17-18, and falls off to around 14 by 5800 or sooner.
http://depositfiles.com/files/ucytd4mgy
An extra -2.7% of LTFT(-1.9% vs -4.68%) can proably explain your difference(leaner) in A/FKrazyrdr83 wrote:Ok, Duster or Don, help me out here.
