Ahem...OK...TCM support anyone???
fernanbfg
Post by fernanbfg »
I have another question about the WOT shifting particularly when downshifting from 6th to 4th/3rd. At highway speeds downshifting from 6th to 5th is fine and driving around town the part throttle downshift is also good between all gears. It's just at WOT it seems like it revs up, slips a little (kind of like the stock shifting) then the rpms drop a tad, then it hits the lower gear. It doesn't feel like the shift is too hard, just not a quick transition bewteen gears. I have it set to the firm shift setting and the 87 Diablew tune. Can you take a look at this log I did and see what you think. I did a couple of WOT bursts at 1:20 and 5:55.
fernanbfg
Post by fernanbfg »
Mike/ Johan, have you had a chance to look at this log?
fernanbfg
Post by fernanbfg »
Bump
No...we have not had a chance...
fernanbfg
Post by fernanbfg »
OK. I read back through some posts from when the TCM support first came out and found a where you revised the shifting multiple times. Is what I am describing above seem to be normal?
fernanbfg
Post by fernanbfg »
I played with the RPM shifting in the ECM part and it helped a little. Definetly shifts better from first to.second.
bulletpryor86
TCM not supported
Post by bulletpryor86 »
I don't think my TCM cal. id is supported, just updated to v.r09d, made some changes to the TCM but when uploaded to truck only the PCM was programmed the TCM reads original backup. Will someone look at this please?
RE: TCM not supported
we'll get it added ;)
bulletpryor86
Any update on adding my TCM?
bulletpryor86
Bump
bulletpryor86
Bump...again
will be in the next update.
riderover
Re: Ahem...OK...TCM support anyone???
Post by riderover »
I have the latest TCM tune on my '11 CTS-V Coupe, when it I force shift (sport mode) down to 1st it shifts with a aweful lurch and shudder. I have reloaded my stock tune , drove the car some then updated the trinity and tuned the TCM again....same condition. With the Oem tune there is no issues...any ideas ??
Riderover (Brandon)
fernanbfg
Re:
Post by fernanbfg »
fernanbfg wrote:Mike,
Do you guys intend to add more TCM functions like part throttle shift points mph or rpm? Lew pretty much has the PCM tune dialed, just trying to get the shift points dialed in now. It seems like there are way more aptions in the Predator, at least for the 4 speeds.
Just wondering if you guys have added anymore TCM parameters in the new CROM?
fernanbfg
Post by fernanbfg »
Bump
Return to “Trinity GM Gas”
