2011 Dodge ram shifting issues...when's the fix coming?
Tyler11Express
Re: 2011 Dodge ram shifting issues...when's the fix coming?
Post by Tyler11Express »
Post the last tune you loaded in to the truck and they'll edit it or you can wait for the update to do it yourself.
Tyler11Express
Tyler11Express wrote:OK just got back from doing a couple test runs with the latest revision and it's still doing the same thing in Drive, 6200 1-2 and then 5800 2-3. It'll hold 2nd all the way to 6200 though if I manually shift it to "3rd"(2nd Prime), but I really want to keep it out of 2nd Prime!
Any ideas or help?
Johan's been busy, I'll bug him tomorrow ;)
white_lightning
Post by white_lightning »
Tyler11Express wrote:I loaded the stock tune and drove it home about 25 miles. I disconnected the battery for a couple minutes then reloaded the latest tune and still the same thing, in drive it'll shift at 1-2 at6200 or so and then 2-3 at 5800 or so. Marku is not having this problem.
Like I said if I manually shift it, it'll hold 2nd to 6200 then I press the up shift on the column to "3"(2nd prime) and again it'll hold till 6200 then I press the up shift to "4"(really 3rd gear). I don't want to go into "3"(2nd prime) at all costs, I want it to shift to 3rd gear on it's own.
Here's the latest tune written,
hey Tyler,
couple changes that are in marku's tune that may help, these settings shifted 1-2 WOT @ 6,267 and 2-3 Wot @ 6,236
tune to try, and marku's log to look at
11 Ram,TEST1RPM[revc 900idle,2kP-T 6.1Kwot[4],P-T Cnvrtr Twk],M.Urban.log
(22.14 KiB) Downloaded 399 times
pcm_68057118ah_w.l._6.1kWot_002,Tyler.drg
(83.96 KiB) Downloaded 324 times
Diablo Dodge CMR Tuner
Cell Phone#: (520) 508-5320
My Ride:
2005 Ram QC 1500, APS converter, 210/214 112 LSA cam, LT headers, True Duals, 4.56 gears, 180* T-Stat and some other mods. Tuned by Me.
white_lightning
d o d g e wrote:
marku wrote:At least it's going to 6090. My 6k tune went 5912rpm and was bouncing
mine just bounce at 5711 in 2-3 gear @ 80mph then bounced again at 6212@ 81 mph before shifting in 2-3
1-2 it hit after 6090 the dropped to 5700 ish @44mph :drivingbad:
if this works for you same as marku, your truck should start to shift about 6,100 and complete the shift about 6,250 for both WOT 1-2 and WOT 2-3
there was an additional part to the rev limit for 11 and 12 Rams. Johan found it and added it to the tune templates.
being able to raise this new part of the rev limit seems to have fixed the issue of not being able to shift WOT above 6,000 for 11 and 12 Rams
11 Ram,93oct LT Hdr,2kP-T 6.1Kwot,ln psi[1]N.Villarreal.drg
(84.02 KiB) Downloaded 402 times
My Ride:
Tyler11Express
Thanks Dave, I'll give it a try tomorrow.
white_lightning
you're welcome Tyler.
keep a close eye on the tach when you try this tune, and let up if it goes much past 6250.
marku is shifting at about 6250 with the same settings, hope they work same on your truck.
11 and 12 Rams act a little odd. have to set shift points for about 6400 to get them to shift about 6100, makes me a little nervous.............
gave you some extra info on the tune in an email.
My Ride:
BryanMcnasty1967
Post by BryanMcnasty1967 »
Hey mikel,
ive seen that yall have corrected the shifting issues on the 2011 ram 5.7 can you help me with mine? I cant figure the download thing was hoping you could help
serial # 6k2890b-1
last version v.1r09g
cant find the calid it just says saved calid:
ive had the problem with the rev limiter and wont shift out correctly at wot
thanks
use dsdownloader to export a copy of the last tune written and post it here please.
BryanMcnasty1967
I don't have it I tried doing it myself and the instructions told me I had to return my vehicle to stock before continuing I did and I cant find the old one now. dude this is frustrating I bought this thing 6 months ago and gave up on it but checked back every once and a while and yesterday I looked and saw someone had the right setup I'm not a computer programmer iIm a mechanic I freaking computer illiterate dude !!!! lol tell me what you need so you can help me and I will give it to you. also tell me how to get it for you! I'm like Cooter from the dukes fix anything but a broken heart but I like a freaking carb and points over a throttle body and electronic ignition any day!!
please boss hog hep me!!!
not sure what instructions you were reading, you only have to restore to update the tool.
If you restore the stock tune, there is nothing in the tool to export :)
Load the tunes, then use DSDL to export the tunes from the tool.
larry613
Post by larry613 »
So did you guys ever come out with a update for the tool yet?
Not yet, Johans been slammed with 2013 stuff, but hes working on it in between ;)
JWM_Jankowitz
Re: 2012 Dodge Ram shifting issues...when's the fix coming?
Post by JWM_Jankowitz »
mikel wrote:use dsdownloader to export a copy of the last tune written and post it here please.
Hey Mikel,
If my understanding is correct I now understand that you have a fix for the 2011 & 2012 shift points?
I have attached a copy of my LastTune written for this mod.
Appreciate the help with getting it sorted.
Cheers,
Mouritz
PCM_68064942AF_LastTuneWritten.drg
(91.99 KiB) Downloaded 333 times
Hey Mikel,
Cheers,
Mouritz
here you go, shifts set to 6100...enjoy ;)
pcm_68064942af_6100_shifts.drg
(86.64 KiB) Downloaded 397 times
