LS1/LS2/LS3/LS4/LS7 etc. - LOGGING, ADJUSTING INJECTOR SLOPE
CANUCKPREDATOR
Post by CANUCKPREDATOR »
Not sure on the power, I know I read it somewhere what the requirements are. Can't find it right now.
USB cable you need to have the drivers for the cable to make it work correctly. You do have to watch, not all cables with work with VISTA, again if you have the drivers for Vista you'd be ok.
Stl_Denali
Post by Stl_Denali »
I have XP, so no worrys there, and I cant get a cable no proplem. Are the drivers with the download from this site??
usb cable drivers?? no, those come with your usb cable....
Stl_Denali
thats right.... so ya the db9 to usb is no prob. I ran the pred while driving for a short time yesterday so i could do a ride along to get the numbers, but i would rather run them into my laptop to get a better tune on this beast.
I found a power adapter... Will this work?
Ac Power Adaptor
model ad-850-06
input; 100-240v~,50-60hz
eing. 1.2A
output; 12V
ausg. Max.50W
1badC6
Post by 1badC6 »
I would dis connect the battery each time cant hurt.
2007 LS2 C6 Z51 6 speed mn
160 stat
Vararam Snake charmer
Kooks 1 3/4 long tube headers
mid pipe w/ hi flo cats
Corsa Sport axle back Quad tip
SLP Predator III
Smooth couplers (Red)
Fast 92 ported
ported throttle body
3.90 gears coming soon!!
08_Z71
Post by 08_Z71 »
Stl_Denali wrote:I found a power adapter... Will this work?
Ac Power Adaptor
model ad-850-06
eing. 1.2A
output; 12V
ausg. Max.50W
Copied from the site here someplace.
2) Power Adapter:
The Predator requires a 12 Volt, 1 Amp power source to turn it on. An AC to DC power adapter allows the Predator to be turned on when not connected to the vehicle. The Power Adapter’s plug tip is 2.5mm in diameter and 5.5mm in length. The required polarity is center contact is positive and the outer contact is ground. Recommended Source: Radio Shack part number: 273-1776, 12V/1000mA AC to DC Power Adapter
08 Silverado 1500 Ext Cab - 4WD - 5.3 - Z71 - Magnaflow - K&N CAI - U7194
Tutorial updated to include new information regarding RPM ranges and DSLogRedux...
you can download this latest tutorial update in PDF format here:
http://www.dslogredux.com/help.html
tutorial updated to include logging parameter info for the older tools which can now log...
here's the info that was added to the tutorial:
** HOWEVER - those of you with the older model tools - 7192, 7193, 7195, 7198 - you don't have the AFR parameter... nor do they all have the commanded throttle position (or Accelerator Pedal Position) either... so you don't need to select those... when you load your 7192/93/95/98 log and verify parameters, it will prompt and ask you if the log was done with a 7192, 7193, 7195, or 7198... answer YES to that, and you'll be fine. It will still go through and filter the log correctly, based on the RPM ranges.
rickssz
Post by rickssz »
06MonteSS wrote:tutorial updated to include logging parameter info for the older tools which can now log...
I only bought my 7198 app 5 to 6 weeks ago and youre saying its an older model? Whats up with that??
don't care when ya bought it, it's an older model... it's for older vehicles... it's been being made since 2000-2002....
I could go and buy a 2002 used car right now off the lot - yeah it's new to me, but it's still on old model car... ;)
rickssz
Post by rickssz »
I dont understand your remarks. I just wanted to know if there is a newer model for GM F bodies out. Should I call Diablo rather than try to find things out on the board???
rickssz
Post by rickssz »
So my 7198 series II revision 2.13 is the most up to date Predator available for 98 to 02 F body GM??
rickssz
Post by rickssz »
06MonteSS wrote:don't care when ya bought it, it's an older model... it's for older vehicles... it's been being made since 2000-2002....
If I bought a used Predator that analogy would make sense. I didnt it doesnt.
rickssz
Post by rickssz »
I am not looking for grief I am looking for help!
rickssz wrote:So my 7198 series II revision 2.13 is the most up to date Predator available for 98 to 02 F body GM??
yes. that is the latest revision and most up to date predator that you're going to find for your vehicle. There is nothing newer.
that's what I meant by it being an older model, for older vehicles... sorry, didn't mean to offend ya...
but it doesn't matter if it was bought yesterday, or 3 years ago - it's the same tool now as it was back then - no changes, nothing newer. It's an older model predator.
