Latest Intune release here.
hello, I have the intune for my 2000 mustang gt. I talked to tech support because I had an old version model number. Listed like..
-diablo tune
-87 octane tune
-modify stock tune
that is it... everyone else has 93 R, 91 P, 89, and 87 P all listed on there screen thats what I am wanting.
He told me to plug it in the pc and have it update. Well it automatically updated or it automatically did something. The model number did change to a different one. I will get the number it changed to when I get away from my desk. Is there a download Just mainly wanted to see what my next options are.
Thanks guys other than this its been a sweet tuner for sure.
-Matt
-diablo tune
-87 octane tune
-modify stock tune
-Matt
mindscapeband
Hi MikeL or anyone able to respond, I have emailed support and cannot find any documentation on this error, the 1000 updated fine and keeps giving this error after some parameter check for my 2011 5.7 Challenger, 68136721AB. Thanks for the help, tried the new release and this doesn't seem to be a bug that's fixed.
i would suggest waiting for an email if you have already submitted to support.
BrianFerry
I just got an email from Diablo, stating that the updates were available for 2013 JK. After I ran the update program, it says to wait while the DCX reboots. The problem is that it's not rebooting. It appears that the file is downloaded, but the installation never finished. Anyone else having this issue?
Re: PLZ HELP
its always good to update the device.Blazerboy wrote:is there a update for the intune???? I have a 09 srt challenger and I have never updated the device...
hey guys i have 1r03p
dcx tune 1r01f
dcx pid db 1r01a
and every time i plug into my 2012 durango tell me that i need to up date to unplug the dcx and plug into a computer other than that it will not let me do absolutely nothing need help
dcx tune 1r01f
dcx pid db 1r01a
the tool is requesting a calibration update. Post your info file, i'll reply with your calibration update
Does anyone have a good tune set for the chevy 8.1...
Is this all up to date. I have a 2012 GMC Sierra 5.3 6 speed
- info.xml
- (3.44 KiB) Downloaded 392 times
VAS, thanks the help last nite and for working overtime. Not to mention assuming me I didn't fry my new 2000 corvettes coupe ecu. Was scary. Seems you were correct, a fuse had to be rest, not broken...just took it out and all gauges/lights worked. Still wouldn't takupdate for a bit so three times blew the fuse. Finally got to work when the reg process connected, run as admin might of been issue on pc? Don't know. DO have the latest builds,
App 1r03r
Gm tune 1r01u
Gm pid db 1r01a???
the car really feels different, even chirps...front end in air it feels like..very nice. So I'll start adding cold air/ls1intake and cat back....will have to mod the canned gm then after each mod? Thanks again. Mike
App 1r03r
Gm tune 1r01u
Gm pid db 1r01a???
I was wondering why I didn't see any of the "canned" octane tunes in the menu after main screen. Only saw "Diablo tune" which I used with no modifications and "modify stock" option I thionk...Do I need to grab these files, octanes and use them accordingly? Im running 93 octane. mike
RexInTheCity
Application: 1r03p
DCX Tune Db: 1r01b
FORD Tune Db: 1r01o
GM Tune Db: 1r01u
DCX PID: 1r01a
FORD PID Db: 1r01b
GM PID: 1r01a
DTC Db: 1r01a
VIN Db: 1r01c
Info Db: 1r01b
Are these all up to date? What is the difference between an ok and * next to the version number under Firmware Info?
I just received my InTune today, spent the hour updating it, and have not had a successful TCM flash yet. ECM works fine.
2011 Silverado 1500 5.3L
DCX Tune Db: 1r01b
FORD Tune Db: 1r01o
GM Tune Db: 1r01u
DCX PID: 1r01a
FORD PID Db: 1r01b
GM PID: 1r01a
DTC Db: 1r01a
VIN Db: 1r01c
Info Db: 1r01b
which vehicle are you tuning. if you only have a diablo tune, thats fine, since you run 93. the Diablo Tune is designed around 93 octane.dtile wrote:I was wondering why I didn't see any of the "canned" octane tunes in the menu after main screen. Only saw "Diablo tune" which I used with no modifications and "modify stock" option I thionk...Do I need to grab these files, octanes and use them accordingly? Im running 93 octane. mike
