Latest Intune release here.
Hello? Does anyone from Diablo actually check the forums?
i have recently put 35 inch tires on my truck and wanted to recalibrate my tire size with the intone and it won't let me. has there been an update that lets u adjust tire size yet i haven't downloaded any of the newest updates and i have a macbook if anyone out there can help me get this figured out
Was told there was supposed to be a new intune update sometime today, hope it comes through soon! lol I want to be able to turn my traction control off again!
connect your intune to your PC and see if it updates...
won't be anything new after now, since they're closed for the weekend...
trey_camaro
i have an 01 f150 4x4 with the 5.4 it says to upload the update but now it wont do it it says error do i have to use the same computer and im regestered on here but my intune will not work right HELP i dont want to have to send it back
Plugged it up and it says it's up to date, guess i'll try on monday? can you let me know if there is a problem adn or if it will be longer?
force check for any updates... if the auto updater comes up and just says it's up to date, then go to the top menu UPDATE - and click on Check Now and it will force it to check for any other updates....
don't know if there's a problem, don't know what vehicle you have, or what your issue is, since you haven't posted about it haha...
as for any fix you're waiting for, I don't know how long it would be.. I don't work down there at Diablosport... I'm a consultant for them, about 2000 miles away.. and any fix you're waiting for, that's something for their engineering department to do...
I have a 2011 challenge r/t, before updating it would let me do everything I needed, but after the update I couldn't turn off trac control, would load for 10% then fail, and wouldn't let me update tire size or gear ratios, so the engineers were to look at it and when I called on Friday Garrett said it should be up right after lunch, but it wasn't up so I tried today but still no new stuff. im patient, I can still use the other functions but for track purposes and some fun id like to shut of traction control....lol
mikblevins
looking for 93 cai tune for a 09 dodge challenger how do I get on my intune
I have tried to update my InTune but everytime it says, "DO NOT UNPLUG!! Updates loaded in inTune. It will reboot automatically. This process my take several minutes, please be patient." I attached a pictures of the what the updater is doing. It just sits there. I have left it alone for hours but nothing changes. My vehicle is a 2013 Chevy Suburban with a CAI.
Here is my Firmware info:
Application: 1r03m
DCX Tune Db: 1r01b(ok)
Ford Tune Db: 1r01n(ok)
GM Tune Db: 1r01s(ok)
DCX PID Db: 1r01a(ok)
Ford PID Db: 1r01b(ok)
GM PID Db: 1r01a(ok)
DTC Db: 1r01c(ok)
VIN Db: 1r01c(ok)
Info Db: 1r01b(ok)
Is my inTune up to date? IF not what can I do?
Application: 1r03m
DTC Db: 1r01c(ok)
VIN Db: 1r01c(ok)
Info Db: 1r01b(ok)
- Diablosport Update 4-1-14.png (73.39 KiB) Viewed 6928 times
Click on the Diablo tune and that is the 93octane tunemikblevins wrote:looking for 93 cai tune for a 09 dodge challenger how do I get on my intune
You can go to the first page of this thread and drag and drop the updates to the intune and update it that way.danzigman wrote:The intune does not attempt to update when plugged in to a windows 7 or windows 8 computer.
Here is what I have.
Application : 1r03h
Ford Tune Db: missing (c)
GM Tune Db: 1t1bb3(ok)
DCX PID Db: 1r01a(0k)
Ford PID Db: 1r01a(ok)
DTC Db: 1r01a(*)
VIN Db: 1r01c(ok)
Info Db: 1r01b(*)
What do I need and how do I install it since neither computer seems to recognize that the Intune needs an update.
I don't think that's the latest update. You may need to either let the tuner sit and finish its process...or you can do the drag and drop from the first page of this thread...drag the update over to the intune folder and it will update that way.
willy4344 wrote:I have tried to update my InTune but everytime it says, "DO NOT UNPLUG!! Updates loaded in inTune. It will reboot automatically. This process my take several minutes, please be patient." I attached a pictures of the what the updater is doing. It just sits there. I have left it alone for hours but nothing changes. My vehicle is a 2013 Chevy Suburban with a CAI.
Application: 1r03m
DTC Db: 1r01c(ok)
VIN Db: 1r01c(ok)
Info Db: 1r01b(ok)
milenkii246
I bought today tuner, windous 7 was unable to update, writes a similar error, but a laptop and beech windous 8 I saw a long process - when it was a slider and what is happening ..
I have a question I need to register their equipment on your site?
I let is sit all night and the updater was still showing the same thing as I posted earlier.
Now my Firmware Info is:
Application: 1r03m
DCX Tune Db: 1r01b(*)
FORD Tune Db: 1r01n(*)
GM Tune Db: 1r01s(*)
DCX PID Db: 1r01a(*)
FORD PID Db: 1r01b(*)
GM PID Db: 1r01a(*)
DTC Db: 1r01a(*)
VIN Db: 1r01c(ok)
Info Db: 1r01b(*)
Can someone please let me know if this is the updated version or not?
Application: 1r03m
GM PID Db: 1r01a(*)
DTC Db: 1r01a(*)
VIN Db: 1r01c(ok)
Info Db: 1r01b(*)
jarhead11 wrote:I don't think that's the latest update. You may need to either let the tuner sit and finish its process...or you can do the drag and drop from the first page of this thread...drag the update over to the intune folder and it will update that way.
Application: 1r03m
DTC Db: 1r01c(ok)
VIN Db: 1r01c(ok)
Info Db: 1r01b(ok)
