2015 Eco Boost Dead peddle Info Thread.
DiabloMatt
Re: 2015 Eco Boost Dead peddle Info Thread.
Post by DiabloMatt »
Roiceed wrote:I've put over 200 miles on with the tune allusions in the sense of no dead pedal. The only issues I saw was once in sport mode when I put my foot in it at 55 it had about a 5 sec delay. And from my original post, the racing feature does not work. In the sense of 0-60 or quarter mile time. The drag tree and motion detect does not work. Not a big deal but I would like to know what the times are and the difference in the times.
Other then that it's been a few days lots of miles. And no dead pedal. Woot woot
we will fix that soon. man power was tied up on this dead pedal thing.
Davidmtz wrote:I loaded the 93 file and I got the check engine light on with a p0234 turbocharger/supercharger overboost condition..
you know what happened?
did you try clearing the code and see if it comes back?
joic0205
Post by joic0205 »
ok is the dead pedal issue resvoled or not? on mine it worked like for 1000 miles before i got the dead pedal i posted all the experince in the wrong thread.
sqeegee
Post by sqeegee »
sqeegee wrote:Since loading 87 test tune I have 3 heat cycles, 8 key starts , 165 miles , and a very happy right foot.
This is all good!!
2 days, 6 heat cycles, 14 key starts 247 miles and all is well!!
There is a Trinity update built and ready for anyone who needs it that allows for loading the tunes with no throttle issues.
inTune and i2 updates will follow shortly.
Thanks for every ones patience in this matter.
Trinity update fix here:
trinity_ford_can_gas-1t13la_update.crom
(3.85 MiB) Downloaded 344 times
intune update fix here:
FORD_TUNES-1t02ea.ITF
(16.13 MiB) Downloaded 222 times
HALFLIFE
Post by HALFLIFE »
Mike is this different from the ones you built for us prior?
kellyfj10
Post by kellyfj10 »
Those features will probably work when they build the tunes for the tool. All they did for us right now is a custom tune.
HALFLIFE wrote:Mike is this different from the ones you built for us prior?
Same tunes, but they all work now. :)
DiabloMatt
correct. update your tools with those and you will not need to use the custom tunes anymore. you can load the regular canned tunes and they should work, please let us know how the new canned tunes work so we know rather or not to do a master release.
sqeegee
Post by sqeegee »
This is all good!!
I tried the 91 canned tune and no throttle, went back to 87 test tune.
euro*
Post by euro* »
got Check engine came on , i was driving on a highway at about 120km/h
came home ran the scanner and got
P0234 error code
Turbo charger/supercharger A overboost Condition.
i cleared it , lets see what will happen now
didn't feel any changes with the engine, drives good , pulls good as well.
thank you for the speed limiter as well , i checked it out today too :D
rovpilot26
Post by rovpilot26 »
DiabloMatt wrote:
rovpilot26 wrote:First post here and glad I found this thread.
Matt, My tuner just came in this evening. Should I wait for the final build before installing trinity on my 15' 2.7EB?
you have a 2.7. it is HIGHLY unlikely you will have a problem. go ahead and install the tune please. im curious if yours will be an issue or not.
I'm presuming that when the motor is running in the driveway, and you push the skinny pedal... motor should increase RPMs?
Put me down for dead pedal. Had to reinstall the stock tune so I could drive to work.
2015bluef150
Post by 2015bluef150 »
mikel wrote:intune update fix here:
These do not work. Loaded 87 tune with no changes. Went 1 block and tried to pull out into intersection with dead pedal. Another near miss accident. Back to stock
DiabloMatt
ok no panic just jet. i half expected this to happen as the tool seems to be stepping all over the checksums. but we had to try it first. could one of you guys load the NEW CANNED tune from last night and when it kills the pedal, post up the last tune written. please. i need to confirm one more thing before i oush a button over here. lol
Return to “General Support”
