2015 Eco Boost Dead peddle Info Thread.
DiabloMatt
Re: 2015 Eco Boost Dead peddle Info Thread.
Post by DiabloMatt »
rovpilot26 wrote:
DiabloMatt wrote:
rovpilot26 wrote:First post here and glad I found this thread.
Matt, My tuner just came in this evening. Should I wait for the final build before installing trinity on my 15' 2.7EB?
you have a 2.7. it is HIGHLY unlikely you will have a problem. go ahead and install the tune please. im curious if yours will be an issue or not.
I'm presuming that when the motor is running in the driveway, and you push the skinny pedal... motor should increase RPMs?
Put me down for dead pedal. Had to reinstall the stock tune so I could drive to work.
rovpiolet, please post up your orginal backup. i need to see if our custom tune will with the 2.7 as well. have not had anyone to test on yet.
rovpilot26
Post by rovpilot26 »
DiabloMatt wrote:ok no panic just jet. i half expected this to happen as the tool seems to be stepping all over the checksums. but we had to try it first. could one of you guys load the NEW CANNED tune from last night and when it kills the pedal, post up the last tune written. please. i need to confirm one more thing before i oush a button over here. lol
Matt- I loaded last nights tune for the trinity. That is the one that gave me DPS (Dead Pedal Syndrome)
Had to do a quick revert to factory to make the trip to work.
DiabloMatt
ok well when you get a chance, please load the tune and then post up original backup
rovpilot26
Just got off phone with Vas. I will reload this evening and post up files. Also worth mentioning, did not see the where to disable auto stop/start.
2015bluef150 wrote:
mikel wrote:intune update fix here:
These do not work. Loaded 87 tune with no changes. Went 1 block and tried to pull out into intersection with dead pedal. Another near miss accident. Back to stock
which tool do you have?
If intune please post the info file, if trinity, check options/show information, and confirm what version is shown.
sqeegee
Post by sqeegee »
sqeegee wrote:
sqeegee wrote:
sqeegee wrote:Since loading 87 test tune I have 3 heat cycles, 8 key starts , 165 miles , and a very happy right foot.
This is all good!!
2 days, 6 heat cycles, 14 key starts 247 miles and all is well!!
I tried the 91 canned tune and no throttle, went back to 87 test tune.
Matt, here is the 91 canned tune with a dead pedal
info.xml
(2.02 KiB) Downloaded 234 times
PCM_PKCMAH2_LastTuneWritten.frg
(165.33 KiB) Downloaded 222 times
DiabloMatt
thank you... this confirmed what i needed... the tool is basically breaking the fix. we are shutting that part off now and and we will reissue an update shortly.
rovpilot26
Matt,
I ended up requesting a service ticket/RMA. Cannot connect to truck or to my PC. The programmer is bricked. I've uninstalled/reinstalled DSdownloader and drivers to PC and it still will not recognize the Trinity. Truck will not let me hook up to Trinity either.
Scheibel
Post by Scheibel »
Installed the new 91 octane tune this evening and still have a dead peddle on my 2015 3.5 ecoboost. Here is my last tune written.
PCM_PKCMAK5.frg
(193.35 KiB) Downloaded 262 times
PCM_PKCMAK5_91_Performance_.frg
(9.25 KiB) Downloaded 221 times
DiabloMatt
ok sit tight....
sqeegee
Post by sqeegee »
BTW, 87 test tune is still going strong, has not missed a beat.
675 miles, 10 heat cycles , 30 or so key cycles, but I did try the canned 91 tune once, don't know if that could reset anything.
Matt, when do you get the fancy logo graphics?
juangorena
Post by juangorena »
Matt here is my files , may i modify the tune on order to get the right tire size ? also i have an afe throttle body spacer and CAI , does it matter ? i´m going to try the 93 performance tune affective today. regards
PCM_PKCMAW3_Premium_Fuel_Performance_.frg
(9.25 KiB) Downloaded 235 times
PCM_PKCMAW3.frg
(193.39 KiB) Downloaded 228 times
garden98
Post by garden98 »
Matt, I'm back in town and now have access to my truck (2015 XLT Lariat 4x4, 3.5 Ecoboost) and can send you whatever you need (if it isn't too late to help). Just let me know what you need sent, and I might need to know how to get the file you need, too. Right now my InTune is just sitting on a shelf and isn't married to anything. Been sitting there since this dead pedal issue raised it's ugly head!
juangorena
juangorena wrote:Matt here is my files , may i modify the tune on order to get the right tire size ? also i have an afe throttle body spacer and CAI , does it matter ? i´m going to try the 93 performance tune affective today. regards
:( no throttle since beginning 1 key cycle
Let him make you new custom tune to fix it.
Return to “General Support”
