Page 18 of 33
Posted: Sat Nov 14, 2009 3:03 pm
by spike1
I've been following this post and tried it on my '01Z71, did the adjustments then drove it for a while and just logged another run but, now it won't down load. I've gone through everything to see why, the usb cable is loaded on the computer but, ? it worked the first time?
Posted: Sat Nov 14, 2009 3:05 pm
by spike1
Posted: Sat Nov 14, 2009 4:27 pm
dude... you posted the same thing 3 times... that doesn't answer any of my questions....
can't help ya until you do...
Posted: Sat Nov 14, 2009 4:38 pm
by spike1
sorry about the triple post, ?. come to think of it, I did not hit the esc button, guess I'll be heading out in a bit to do it again. thanks.
Posted: Sat Nov 14, 2009 9:30 pm
by spike1
ok, did another log run, at end of log did it properly yet still nothing, usually a screen pops up when I plug something in to download but not with this
it might be the cable, it worked once. I tried it on another computer, same thing, nothing.
Posted: Wed Nov 18, 2009 4:51 pm
by spike1
Back again, swapd out the cable for a new one, still nothing, my guess is it's in the predator itself. any fix or diagnose for this?
Posted: Wed Nov 18, 2009 4:54 pm
sounds like you don't have the usb drivers installed for the usb cable man...
Posted: Wed Nov 18, 2009 5:19 pm
by spike1
that was done, like I said it worked the first time
Posted: Wed Nov 18, 2009 5:22 pm
is the predator powering up when you plug it into the power adapter?
Posted: Wed Nov 18, 2009 5:35 pm
by spike1
powers up good any ideas?
Posted: Thu Nov 26, 2009 5:43 pm
by aggie88
I had my LTFTs on my LS2 Corvette set at 1 before I installed a ported FAST 92 intake. I took a new log and now the LTFTs are about 5% off. This sound about right? It seems right to me, the LTFTs went up about 4% requiring a trim down of 5%, or pump more fuel into the injectors due to the improved air flow.
Or do I need to adjust down 5% PLUS what I already adjusted to get to the 1% prior to installing the manifold?
Posted: Fri Nov 27, 2009 9:30 am
since your first injector slope setting is still in the tune, and now your ltft's are off and it's telling you that you need to go -5% on your slope, then that is in addition to the current setting...
so, for example, if your slope setting is already to -3%, and now you need to go another -5%, then the slope adjustment on the predator will need to be set to a total of -8%...
what is your current injector slope adjustment set at?
Posted: Fri Nov 27, 2009 6:03 pm
by aggie88
06MonteSS wrote:since your first injector slope setting is still in the tune, and now your ltft's are off and it's telling you that you need to go -5% on your slope, then that is in addition to the current setting...
Thats what I thought, I am trying to retreive the csv for my current tune. Its probably about -4 or so. I guess if I cannot find it, I should restore the factory tune and run a log from that? Or should I do a Diablotune and run a log?
Posted: Sat Nov 28, 2009 9:41 am
noooo... you always want to do the logs with the tune you're gong to be using and have installed in the car...
so, keep the diablo tune in there, since that's what you'll be driving on anyway... that's the tune you need to do the data logs with...
Posted: Wed Dec 02, 2009 12:57 pm
by JohnyBeeO
Hi MonteSS
I come from switzerland and i read your toutrial, first a big praise to you and Lewis for the really great work.
Now i have adjustement my injector slope and my cars running good. Whats the next step to get all hps out of my engine? WOT?
For the records i use my notebook and record the data with the Dataviewer. And another question, do i shorted my lifespan of my engine with this tune?
