2015 Eco Boost Dead peddle Info Thread.
Re: 2015 Eco Boost Dead peddle Info Thread.
Hey Mike, is the program ready to update and run normally?
i updated my itune and it was worse the first time i could drive for like 1000 miles with the update only drove 2 miles and got the dead pedal issue, did i do something wrong or did the update not work at all?
juangorena
Thank you i'll wait , regards
mikel wrote:Let him make you new custom tune to fix it.
DiabloMatt
juan here is your custom tune to fix it.
- test93 juan.frg
- (144.11 KiB) Downloaded 235 times
DiabloMatt
joic0205 wrote:i updated my itune and it was worse the first time i could drive for like 1000 miles with the update only drove 2 miles and got the dead pedal issue, did i do something wrong or did the update not work at all?
were almost done. its going to be building today.
DiabloMatt
hey buddy. plug tool in and select a tune. let it read the backup. when it asks if you want to install tune. click no. (backup will still be in truck). plug tool into computer and psot up the original backup.garden98 wrote:Matt, I'm back in town and now have access to my truck (2015 XLT Lariat 4x4, 3.5 Ecoboost) and can send you whatever you need (if it isn't too late to help). Just let me know what you need sent, and I might need to know how to get the file you need, too. Right now my InTune is just sitting on a shelf and isn't married to anything. Been sitting there since this dead pedal issue raised it's ugly head!
DiabloMatt
ok guys....;ets see if this works... here are updates for the trinity (crom) and the regular intune (itf).
please return your vehicle to stock and update the tool. then try the can tune of your choice
please let me know asap if it works
- FORD_TUNES-1t02eb.ITF
- (16.12 MiB) Downloaded 244 times
- trinity_ford_can_gas-1t13lb_update.crom
- (3.85 MiB) Downloaded 214 times
No pedal right out of the gate
- PCM_PKCMAH2_LastTuneWritten.frg
- (165.35 KiB) Downloaded 218 times
- info.xml
- (2.02 KiB) Downloaded 219 times
Matt, I'm updating the tool as I type this, and will then get you the files you want, but based on sqeegee posting that the update you put on this forum today (FORD_TUNES-1t02eb.ITF) resulted in a dead pedal right out of the gate, should we hold off on putting that in? Had a really close call before with the dead pedal on the interstate, and would rather not chance that on the way to work tomorrow!
DiabloMatt
garden98 wrote:Matt, I'm updating the tool as I type this, and will then get you the files you want, but based on sqeegee posting that the update you put on this forum today (FORD_TUNES-1t02eb.ITF) resulted in a dead pedal right out of the gate, should we hold off on putting that in? Had a really close call before with the dead pedal on the interstate, and would rather not chance that on the way to work tomorrow!
yes hold off. there is one more glitch apparently
i can still get you some custom tunes to use in the mean time
Just got the i2. Looking for a Custom Tune for 2015 3.5 Ecoboost or I can wait if that makes more sense.
Fred
Fred
- PCM_PKCMAW3_Backup.frg
- (165.69 KiB) Downloaded 204 times
Hi , Just got the new I2 today. 2015 f150 supercab XLT 2.7, 3.55 gears. Updated tuner and installed 91 tune, had dead pedal. Returned to stock then tried to load 87 tune with same result. Located in Maine. Glad I found this thread and Forum because I was pretty worried about the dead throttle.
Thanks,
Brian
Thanks,
Brian
Matt, here's the original backup file from my 2015 Lariat 4x4 3.5 Ecoboost. Couple of things, first, I haven't used the intune since the first week of June when I first had the dead pedal issue, been waiting on a fix. The intune wouldn't read the backup at first, kept telling me I need to update calibration. It took a while, but I finally got the updates and then let the tool download the original backup from the truck. It took a while, but I just got the latest PCM updates from the Ford dealer a few weeks ago, and wanted to make sure I could put it back. Now sure what DiabloSport has if I downloaded the original backup from the computer, but I know the Ford dealer had the latest. I've been trying to get the 87 Octane Tune working since I got the truck. Hope you can help!
- PCM_PKCMAG2_Backup.frg
- (166.08 KiB) Downloaded 272 times
DiabloMatt
here you go go sir. drop this into the main intune drive. then go load in the truck.
- garden 87.frg
- (146.12 KiB) Downloaded 220 times
DiabloMatt
fsanders: here you go sir.
- fsanders 93.frg
- (145.59 KiB) Downloaded 229 times
- fsanders 87.frg
- (145.68 KiB) Downloaded 211 times
