Diablosport tune makes my gto run really really really bad
Grumpy_Aero_Guy
Re: RE: Re: RE: Re: RE: Diablosport tune makes my gto run re
Post by Grumpy_Aero_Guy »
mscheaf wrote:OK here is what I will do.
1. I will remove the IAT relocate just to eliminate that as an issue. While doing that I will look closely at the maf to determine oem or not.
SOund like a plan?
Yes, many GTO folks relocate the IAT sensor because of heat soak in the engine compartment, especially if they're at the drag strip. Usually, these guys are tuned appropriately to take avantage of this change.
A "false high" (relative to true ambient temp) IAT temperature reading will make the computer think the air is hotter than it is, i.e. less dense, and therefore inject less fuel to achieve a fixed target Air Fuel Ratio, regardless how the false high originates.
Consequently, a "false low" will do the opposite, and it will inject more fuel leading to it running rich relative to a targetted AFR.
Now, here's what I don't know, relative to the GTO:
Do the stock tuning tables "correct" the KNOWN/ANTRICIPATED high readings given the IAT sensor is in its stock position.... and, once it's moved, without updating/correcting the tuning tables, is the control doing what it THINKS is right, but missing the mark.
Now, did you install any kind of a resistor with the IAT move. I do know that some folks do THAT in order for it to read different, thinking that it will force the control to provide more power (false premise).
Not sure. The acid test, of course, is getting everything back to TRUE STOCK configuration, insuring that the stock tune performs OK, THEN installing the tune, and seeing if drivability problems persist.
Pain in the arsch, I know, but that would lead to some more targetted knowledge as to what's going on.
DSLogRedux.com
mscheaf
RE: Re: RE: Re: RE: Diablosport tune makes my gto run really
Post by mscheaf »
file sent
mscheaf
Post by mscheaf »
And yeah i removed the iat relocate kit. All back to stock now
Grumpy_Aero_Guy
Oh yeah, a LOG FILE would br REAL helpful here...... (csv file)
DSLogRedux.com
mscheaf wrote:file sent
got it.. cool...
I will look at it tonight when I get home... about 6pm EST and letcha know what I find...
thx
mscheaf
RE: Re: RE: Re: RE: Re: RE: Diablosport tune makes my gto ru
Post by mscheaf »
ok well in the mean time would a log file during the "running like crap" period help?
yes, absolutely... may give us some insight as to what's happening...
mscheaf
Post by mscheaf »
OK quick question. What is the GMLS2Interfac program used for?
for importing/exporting tunes between the predator and your PC
mscheaf
Post by mscheaf »
I thought the dsdownloaded did that
mscheaf
Post by mscheaf »
Sorry DSDownloader. I thought that is what that was for
mscheaf
Post by mscheaf »
Here is my log file. When I looked at in all on the graph, all the stuff was jumping up and down like crazy. It is not a horribly long log (about 30%). The beginning and the end are where it was driving like crap, the middle is where i was waiting at a red light to do a u turn and come back home
well, aside from your trims needed to be adjusted and you have a lot of KR, don't really see anything that whacky...
mscheaf
Post by mscheaf »
SO it is normal for the values to jump up and down like that? When I looked at it in the dataviewer everything jumps up and down a lot.
yeah, dataviewer shows you a compressed timeline, so it looks like big ups and downs... if you look at the data in the excel file, it's not that drastic with the ups and downs...
your KR - yeah, that's drastic LOL from 0 to 4, 5, 6, 7, even 8 I think I saw in some spots... shouldn't have KR like that when just normal steady driving...
what brand and octane gas are you using? and which tune do you have installed?
