GM gas Predator hardware upgrade program in place!
RE: o4 avalanch speedometer
nah... this issue happens with 7194's as well... so it's not just you guys...
goosemanx , ive emailed them a download of my stock program so they can see what the problem is. They think my truck had a dealer change the reprogram the tire size and that overides the v7193. maybe this will help u to.
06montess, have u had any luck getting uresfixed???
I don't have your guy's problem...
I have my stock 18" wheels/tires on, so never had to change that stuff...
jbristow,i maxed out tire settings parameters, scroll down to apply and select, install tune, you will notice like a 40 km/h speed difference, i used a gps but the difference in speedo and actual speed is so great that you doon't even need a gps to confirm that the tire parameter is set even though the predator says tire width,ratio,and rim size is not set.Try this to see if yours is the same,
MAX OUT ALL VALUES SELECT APPLY INSTALL TUNE
it worked for me
it worked for me
ok ill give it a try thanks
goosemanx, i maxed out all the tire sizes and still no change to my speedometer . thanks for ure help . mike has a copy of my stock program and maybe they can figure out whats wrong . thanks again.
i have a u7195 that i used on my 03 h2, reprogrammed to stock and traded in for a 03 sierra 6.0 can i use the it on my new truck? came from granitelli thanks for your help
I bought mine on EBAY for $120 haha. Its a 7192 with a 2.xx. Update available for me? Also what is the difference in the performance tune? Is it more aggressive? Im kinda iffy on this one because im fixing to go with longtubes and I dont want to have a CE light on for o2's... Might be worth it if it will help my off idle to 3000 though.
m8silverado
Anyone applied for a RMA to get the updated Predator? How long or days did it take? I've been waiting 3 days now and no response.
m8silverado
Hello, anybody out there? Still waiting.
WHat is the name you filled it out under?
m8silverado
Allen Singleton
m8silverado
Subject: DiabloSport RMA request form for Allen Singleton (autogenerated)
Date: Feb 2, 2009 8:51 PM
This is autogenerated by diablosport.com
THIS IS NOT THE RMA CONFIRMATION
You shall recieve an RMA Confirmation shortly
If you have any questions you may call the RMA Dept: 561.961.2437
Keep this for your records.
New RMA Submission Form: 02-02-2009
Name: Allen Singleton
Num U7195
Bought From Premier Performance Products
Serial Num 159904
Description GM Class 2 upgrade
Num U7195
Serial Num 159904
m8silverado
If someone has gone thru this RMA dance to update their tuner help me out. How long does this go on? I know I'm impatient but I think this long is outta control. Especially when you have to give a credit card to even get the process started, let alone who knows when it gets finished.
