Analog inputs - more info
RE: Re: RE: Re: RE: Analog inputs - Need more info
cool. Il be sure to test it out once its released. Thanks John
does it have to be a stereo plug? I found one that's a mono jack, but hey it's free! I havent hooked it up mainly bc of the weather (temp being -5F to 10F lately). This weekend is gonna warm it up to 40F! whoo-hoo!
SRT-4 DiabloSport Trinity Beta Tester User
I say this without having tested it myself, but the mono jack should be fine, the obvious downside being that both inputs will read the same value.
johnc <at> diablosport.com
I only have 1 item for input and that's just my wideband.
Any updates?
Josh - 2005 Black Neon SRT-4
S2R0T044 at srtforums.com
Trinity tuned.
Trinity tuned.
Ok question about logging the serial stream.
Can the Trinity log the data from say something like an Innovate SSI-4 ?
-R
-R
Currently the Trinity has two analog inputs. The connector on the back of the Trinity is for serial input, which is what you would need since the SSI does not output an analog signal. Keep bugging DS about serial inputs on the Trinity and maybe they will finally listen and implement it.
Well isn't that special....
Ok I would almost be happy with a PDF that freaking works.
And why did this get moved to the Dodge Diesel Trinity Sub forum vs the General ?
-R
-R
Re: RE: Re: RE: Re: RE: Analog inputs - Need more info
which PDF is not working?RobAGD wrote:Well isn't that special....
-R
RE: Re: RE: Re: RE: Re: RE: Analog inputs - Need more info
Trinity Manual, it just pukes all over itself.
This Laptop, my net book and 2 desktops.
-R
-R
Hmmmm, just opened right up for me Rob, would you like me to email it to you?
Try this:
- Manual.pdf
- (29.26 MiB) Downloaded 1208 times
