u7146 not taking 7r50d crom
Shaken
Post by Shaken »
dbelld wrote:Back on subject, I want to thank Shaken for the helpful link. I found the problem to be a clogged hose going to the DPFE sensor. No custom tune needed anymore. I thank Diablosport for having these forums to get different views to problems and Vapor 7 needs to calm down alittle bit before they blow a gasket. :)
Your welcome. :D
2003 Mach 1 K&N cai w/screen
Accufab 60mm Twin TB Steeda Tri-ax
Predator custom tune +1 lean 2k-4k, +1 lean 4k-7k
AFR 12.6-12.8 3/8" Roy Spacer IAC plate
Bassani O/R X 2.5 flowtubes to Delta 40's
w/factory tail pipes
Return to “Predator Ford Gas”
