The two slopes (correct vs incorrect) will diverge at higher values. If its .4psi off at 1bar, it could easily be off 5psi once you get to 2.5bar.DRASTIC. wrote:duster360 wrote:DRASTIC. wrote: And his last email told me to "check baro logged on DSDV and check actual BARO and tell me the difference and ill adjust it"
not sure what that's spose to mean... :dunno: Baro is 14.33 at ign on, car off. not sure what else he wants from aside from that.
And I already told you how to do that too. I guess you didn't bother to listen then either![]()
"Baro around here floats between 14.2-14.8psi depending on the weather. I suggested a separate independant [barometric pressure]gauge. Weather report will work too."
Get a Barometric pressure gauge or call the local weather man.
If your Baro PID says 14.33psi but the weatherman or Baro gauge says 14.79psi, tell Brain that the BARO is (14.79 - 14.33 = .46psi) .46psi off.
gotcha. sorry for the hard headed-ness. if i was a proficient tuner, i wouldn't exactly be in this predicament...lol
looked up weather for my town, and baro is 29.97in (mercury, i assume yes)
went to http://www.convertunits.com/from/inches ... bsolute%5D
and 29.97in equals out to 14.7198psi
14.7198-14.33 = .3898psi
is that linear, or how does that work in retrospect to the map scaling? because at upper psi, its off more at say, 20psi, than what it'd be at 5-10psi.
thanks for the help..
Just tell Brian its off .3898psi off.
