Page 3 of 19
Posted: Wed Nov 03, 2010 5:53 pm
by juankatrina
ok how and do I get that tune file from my tuner? What does it consist of? Not sure exactly what you mean or how to get it.
Posted: Wed Nov 03, 2010 9:55 pm
by blazingzz
What is the proper way to add it to the tuner. Do you take the truck back to stock and then do a tool update or do i add tune file to the tool. Thank you Johnan
My truck is in the shop now getting new seat covers per some recall and they are inspecting my lift but I will get it back Thursday night. I will download it and drive it Friday and this weekend I will keep you posted on how it is acting. Thank you
Just curious what did you focus on with this change. The tranny jumping. Did youlook at the idle issue or shift firmness. Thanks Johan
Posted: Wed Nov 03, 2010 11:55 pm
by 09Laramie
johan wrote:See if this one helps for you as well and please let us know.
Thank you for checking this out. Will test it out tomorrow morning and try to post again with results asap.
juankatrina wrote:ok how and do I get that tune file from my tuner? What does it consist of? Not sure exactly what you mean or how to get it.
Downloading tunes from the tool
blazingzz wrote:What is the proper way to add it to the tuner. Do you take the truck back to stock and then do a tool update or do i add tune file to the tool.
Sending custom tune to tool
Found both of those documents, and some other interesting info on the
Support Documentation page.
Posted: Thu Nov 04, 2010 12:32 pm
by johan
He he, thank you ^^
2009 Ram Hemi Tranny Jumping and Rough
Posted: Thu Nov 04, 2010 11:37 pm
by juankatrina
Johan,
Here is my last tune that I installed that is causing tranny being rough and shaking at WOT @ 40-55 mph.
RE: 2009 Ram Hemi Tranny Jumping and Rough
Posted: Thu Nov 04, 2010 11:40 pm
by juankatrina
Johan,
Hopefully you can have tune back to me before weekend so I can give it a try.
Posted: Fri Nov 05, 2010 12:36 am
by 09Laramie
Tried the tune this morning- didn't experience any of the shaking that I described before. Also seemed a bit smoother in general when accelerating from low rpms without the transmission downshifting.
I'll keep monitoring it and let you know if the shaking comes back.
Thanks again
Re: RE: 2009 Ram Hemi Tranny Jumping and Rough
Posted: Fri Nov 05, 2010 8:50 am
by johan
juankatrina wrote:Johan,
Here you go, please let us know asap so we can make an update for this.
RE: Re: RE: 2009 Ram Hemi Tranny Jumping and Rough
Posted: Fri Nov 05, 2010 10:02 am
by blazingzz
I will not be able to try the new tune out till Saturday, the dealer is not done with it yet. I will try it out this weekend and I will let you know how everything is Monday thank you Johan.
Posted: Fri Nov 05, 2010 10:18 am
by johan
Ok cool cool, i have a wrangler update i am holding up for this so the sooner the better, trying to make everyone happy
Posted: Fri Nov 05, 2010 7:58 pm
by juankatrina
johan,
I installed the tune and I still have the shaking at WOT @ 40 to 55 mph. So its still having problem. The shift points seem quicker also between shifts but not as firm as before. Any more ideas what it could be? I also modified the paramathers on this tune. Could modifying your tune keep causing it, or should I just try your tune as it is?
Posted: Mon Nov 08, 2010 9:20 am
by johan
What parameters did you modify? And i would suggest trying to run the tune without the parameters modified just to check.
Posted: Mon Nov 08, 2010 9:32 am
by juankatrina
I also over weekend tried with changing parameters and still having same problem. The parameters I changed at first was the throttle sen to 20%, shift points 1-2 to 6000, 3-4 to 6100 & rpms in drive to plus 600. So I tried them both and no change.
Posted: Mon Nov 08, 2010 9:33 am
by juankatrina
Over weekend I tried without changing parameters and still same problem. Just had to clarify my last post.
Posted: Mon Nov 08, 2010 9:41 am
by johan
Are you sure you loaded the tune in properly? I saw you posted some questions on how to so i have to ask.
