2011 Mustang V6 Tunes Available ?
We're trying to find a local car with this calid since it works fine on the bench.
OK, new update...still have not gotten my hands on a car with your calid, but give this a shiot.
be sure to reselect your vehicle from the list after loading the update.
- trinity_ford_can_gas-1r08a_update.crom
- (2.11 MiB) Downloaded 178 times
(( Bangs head against the steering wheel ))
Mike,
Still a no go, unable to save original tune (-14)........
And as mentioned before, I immediately did a engine diagnostic: U0300 Unknown/P0600 Serial Communication link, once I clear it... its all good.
Does fine with monitoring.
(( Bangs head against steering wheel again ))
Mike,
OK, thanks.
I think we have a line on a local car with the same calid, which will make it easy to fix.
So... any luck with the car and or the fix? If you need a car with the calid I'd be glad to help out. I'm not Strictly local but I wouldn't mind driving down there if that means it gets fixed before my trinity collects any more dust.mikel wrote:OK, thanks.
And about the paperweight... it's not even heavy enough for that.
How not local are you?aimjhay wrote:So... any luck with the car and or the fix? If you need a car with the calid I'd be glad to help out. I'm not Strictly local but I wouldn't mind driving down there if that means it gets fixed before my trinity collects any more dust.mikel wrote:OK, thanks.
Sooner I get a car in here the sooner i will have a fix.
And, if you decide to come down, I'll make sure your car leaves with a tune, regardless of the trinity working or not
No, but I have determined that we can use ANY V6 and stick our bench PCM in it to try to duplicate the issue.
Are you all automatics?
