T42/4 speed TCM test crom available
Ill_Born_SS
Post by Ill_Born_SS »
Blueox, the Crom listed in your tools list above is not the most current (trinity_gm_can_gas-1r08g_update.crom )( actually hi ) and you need to also have the ( trinity_gm_j1850-1r08d_update.crom )
So hook up to your computer and DsDownloader and update to all the most current software first.
when completed this line :
CROM version = 'trinity_manager-1r08b 04/14/2011 01:41:27 PM boot4'.
should look like this:
CROM version = 'gm_can_gas-1t08hi 12/13/11 15:48:24 boot3'.
" Just Friggin Wicked"
Now with TCM support...
uggh.
looks like that tool will need to come back here to be checked out.
otiswilsonjr3rd wrote:I downloaded the new crom and tried it with the diablo tune, i select modify tune and it shows the option of pcm or tranny. i tried to modify the parameters and some times on the normal shift rpm it would say "trinity does not support this vehicle call (561) 909-0400" i'd back out and try again and it would allow it but show random rpms like 5600 one time then 0 then 340 etc..other time it would show parameters not available for this vehicle/tran combination. under show information it has pcm: diablo tune (modified) tcm: original back up. here is a copy of the original and last tune written files. p.s. it is a 07 nbs vortec max
can you go to options/troubleshooting/show calid and tell me what is listed there?
(everything).
otiswilsonjr3rd
Post by otiswilsonjr3rd »
pcm:
12614088 (main os)
12614246 (system)
12614219 (fuel system)
12614306 (speedometer)
12614188 (engine diagnostic)
12616014 (engine operation)
12605899 (slave operating sytem)
12604049 (engine)
tcm:*
24239036 (main os)
24237445 (transmission)
24240466 (transmission diagnostic)
24237444 (system)
thanks
johan
Post by johan »
There is something very odd with your trans calibration, your VIN does not even show what you have listed above as ever being for your vehicle, i have seen those trans calibrations in cars.
By any chance you would not be able to get it flashed at the dealer ? Your engine cals are pretty old also.
You can go on this site and verify if you want, http://tis2web.service.gm.com/tis2web just enter your vin and it will show you everything that is available for your vehicle.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
otiswilsonjr3rd
What do i tell the dealer the reason i want it reflashed so it does'nt throw up a red flag?
just tell him you want the latest calibrations.
tell them you heard on the forums that it makes the truck run better...
otiswilsonjr3rd
ok thanks i'll see what i can get done then i'll send you the updated files.
Blueox
Post by Blueox »
when i got the file i restored the original file then updated i checked the list it did say 1t08hi after that i installed the 87 oct thats when everything went for the craps no idea:( ok so how do i send i back iguess if thats the only thing i can do
fill out the rma request form on our site here under support.
otiswilsonjr3rd
Got the pcm/tcm reflashed at the dealer, the tcm tune installs now and shifts seem quite a bit firmer but cant tell much difference on torque management. I'll drive it some more and see how it does.
johan
Post by johan »
Damn, that was quick, good deal thou.
Think you could verify that you see different numbers now in the show calid section maybe?
Diablosport INC
yeah...quick is an understatement.
Glad its all worked out :)
CANUCKPREDATOR
Post by CANUCKPREDATOR »
After a couple of days of around town driving on the firm shift canned tune, this is pretty nice. Firm but not jerk your head off. At part throttle don't really notice alot of change, but firmer. At 75% throttle plus things get quite a bit firmer and 1-2 for me is quite snappy since i've got the corvette servo. Going to install hard shift tune tonight and a couple of days of that and we'll give more feed back then.
Return to “Trinity GM Gas”
